Hello, our department has a Sharp AR-550U. The option for Stapling (using it a a netword printer) is greyed out when trying to print. I have provided all users with manage document permission. The stapling works when the employee uses it as a copy machine. Thanks, Roy
  • 47 Answers
Go into the printer properties, if you are using a print server then this must be done on the server, not the workstations, go to the "configuration" tab and tell the driver what options you have installed then clickk apply.
Posted on Jan 03, 2009
HOW TO REPLACE THE PRINT DRUM ON A SHARP AR-208D COPIER
  1. fold down the bypass tray on the right
  2. hit grey button on right door to open it
  3. fold the front cover down
  4. press green button to remove the toner
  5. the drum is the other thing you can grab and there and remove.
  6. reassemble in reverse order of 5-1
Jun 09, 2014 | Sharp AR-208D Printer
How can i get aproduct key online ?
Your request is confusing and lacking details, but I'll try....
The base model 550U has USB and parallel printing capability. Networking comes standard on the 550N but is an add-on option for the 550U in the form of a "print expansion kit" made up of a NIC, 2 flash rom that plug into the main control board, and a product key. If the area where your print ports are located has a network CAT-5 plug, it means your expansion kit is installed, your product key has somehow gotten zapped and you need to re-enter it. The model number for the kit is AR-P19. If you have the P19 box with the registration sheet, the product key may be written on it. Product keys can be obtained online but only a Sharp dealer has access, sorry.
May 01, 2014 | Sharp AR-M550U Copier
We are trying to connect the Desk top PC so as to use AR=5316 as a printer.Need help to install the printer software. Can I get it downloaded from Sharp site. Please reply.
you may gey the driver software for AR=5316 printer install sotware inthese websites
http://nodevice.in/driver/AR-5316/get47086.html
http://ptf.com/sharp/sharp+ar+5316+printer+drivers+to+support+windos+7/
Apr 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
My Sharp copier AR 5316 does not work with Vista business service pack-1. It does not work when print option given for current page and printer sleeps and does not take the printing order. One has to...
have you installed the PROPER Vista driver? Or just used the install disk that may have come with your machine years ago, and may not be designed for "Vista". Go to sharp and download the proper driver, or at least see if it is supported.
Feb 01, 2010 | Sharp AR-5316 Advanced Digital Imager...
Cant staple from driver but can staple directly from the machines panel ... particularly 8x14
Most Likely the issue is resolved by configuring the driver properly. If you right click the printer under Printers and faxes in your start menu you need to go to properties, then to the configuration tab and then to Auto Configuration. it will then communicate with the printer and find out what options are installed and then enable you to use stapling from your computer. Make sure to select where the hands are pointing also. thanks. you will understand.
May 15, 2009 | Sharp MX-3501N All-In-One Printer
Printing by SHARP AR M161 on Mac 9.2.2.
Go to printer setup and click on new printer. You should get a long list of printers. Hopefully yours is on the list. Click on the printer name and you will be presented with several drivers. Choose the one that is the best for you. Before you exit print a test page. Give the printer a name.
If this does not work you will have to install the windows driver. This is only possible If your Mac can run windows software.
Mar 04, 2009 | Sharp AR-M162 All-In-One Laser Printer
Sharp AR 168D will not print from PC
Try disabling the print queue. In windows 2000 go to printers, then properties of the canon printer, advanced and select "Print directly on the printer".
Also try printing from another computer and replacing the interface cables.
May 05, 2008 | Sharp AR-168D Copier
Sharp copy/printer to staple Crystal Reports
this should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
Mar 26, 2008 | Sharp AR-M550N Copier
62 people viewed this question
jasbo
jasbo
