Question about Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator
Freezer just not getting cold enough. Freezer fan is running. Gasket, I thought was the original problem, has been re aligned. Light switch works and the light goes off when freezer is closed. Cold air is circulating, but it's just not cold enough. Fridge is 3 1/2 yrs old.
  • 1 more comment
  • Bruce Carwardine May 05, 2007
    Alright, problem solved. Apparently an object came loose out of the freezer compartment and jammed the gasket out of shape. Over a few days the freezer has become totally frosted up. I'm currently defrosting it with a hair dryer and hope that this will solve the problem.
  • Bruce Carwardine May 26, 2007
    Here we go again. 3 weeks later and the freezer is starting to ice up again. There must be a problem with the defrost cycle. Any ideas?
  • djsouthwell Sep 27, 2008
    Fridge is not cooling. PBF2553HEB Maytag, Freezer on Bottom.
    Problem Solver:
  • 14 Answers
The defrost heater element is bad, Do you know enough engineering to tackle the job ? You will need some hand tools and a spare Saturday afternoon .. Alternaively you could call a technician...
Posted on Sep 17, 2007
SOURCE:
The freezer is not enough cold, i check the defrost sensor, temperature sensor and its are ok, but the evaporator fan motor is not working... why? i check this fan too and is ok. Now what can i do??
It could be on automatic defrost mode, let it run for a while and see if it gets cold enough, also if you have the freezer to full and stuff near the cooling fan in the freezer, the freezer can not circulate to get cold.
Mar 01, 2015 | Refrigerators
Freezer not getting cold enough
Open the freezer door and push the light switch in, is the freezer fan running?
One possible problem is refrigerant leak. Pull the freezer back panel off and check evaporator coils for a partial frost pattern.
Apr 10, 2012 | Refrigerators
My Refrigerator is running constantly. the settings are 3 on bottom and 5 on top. The food in the top is cold and the freezer is very cold -10, but is also building up ice. Is it possible the baffle is...
Hi and welcome to FixYa, I am Kelly. DO NOT change the settings. You most likely have one of the following problems:
1. Automatic Defrost
2. Evaporator fan not running.
First check the door switch... make sure the light goes OFF and the fan goes ON when the plunger is depressed. If the light stays on with the plunger depressed the fan will not run.
Next check the condenser coils in the back of the unit inside the fiberboard access panel. Make sure the fan is running and that the coils are free of lint.
As for your unplug it thought.... this is actually what we recommend to do after the steps above.
However... there is a much quicker way than just unplugging it.
Do this to get rid of ALL the ice build up:
Unplug the unit and remove freezer contents
Direct a fan into the freezer compartment for just over 2 hours (yes water mess!)
After the 2 hours clean up the mess and return the unit to normal service.
AFTER 2 - 3 Days... Check again for signs of ice build up. If you notice ice build up starting again there is a problem with the automatic defrost circuit. Otherwise... no worries.
The symptom you have can also be caused by a door gasket problem if it is torn somewhere that is allowing air into the freezer when the door is closed. Just make sure the door gasket mates to chassis all the way around the door.
Any questions or comments just respond here and I will help you.
Thanks for choosing FixYa,
Kelly
Mar 05, 2011 | Maytag MBF1956HES Stainless Steel Bottom...
HI,my freezer runs fine,but I noticed where the motor side is,should there be a fan??,I feel no air moving.didn`t try to take off cover an look.an the freezer gets alot of ice at the top sides.thanks
Good day,
Unlike most refrigerators and upright freezers, they don't use a fan motor. The condenser coils are imbedded in the walls of the machine, and need no supplemental cooling.
As to the ice buildup, sounds as if the gasket isn't sealing well enough. You could try cleaning the gasket thoroughly, and check the alignment of the lid to the body.
Appliance parts houses carry a food compatible spray, which may help make the vinyl more pliable.
If that doesn't work well enough, then the only option is replacing the whole gasket.
With the model number, check with the supply house to see if the gasket is a replaceable style.
Nov 03, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Freezer fan not running
Often times the defrost termination switch (which opens when it gets warm enough) will hold the fan off until it closes again when the freezer runs. It is possible that the switch is not closing, but be sure the freezer is getting cold enough for it to close.
You know the freezer is likely cold enough when you see frost covering the entire evaporator coil after a few hours of operation. A partial frost pattern could indicate low refrigerant, or a restriction of refrigerant.
May 29, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator Logo
406 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
