Hi, our TV turned itself off and now won't turn back on- the green and red lights just flash, but no picture. Any ideas what is wrong and how to fix it? x
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
or a new lamp. you could first replace the lamp. the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Hi.
Thats a nice tv you have there.
If your able to get free estimate from repair shop go for it.
It could only be dry joints but it could be loptx & other components which could be pricey.
is there a way of resetting it without having to have the screen on?
