Question about Sanyo VM-PS12 8mm Analog Camcorder
Tape wont eject
Have an old sanyo 8mm camcorder VM-EX22P tape wont eject help!
  • 33 Answers
The deck may have went. Try bringing it to a local camera shop to get it out for you.
Posted on Dec 31, 2008
I have an old Video Camera, Sanyo VM-RZ2R 8mm camcorder. I can't get the cassette holder to eject. There's no cassette in it at the moment but when I press the eject button, the camcorder turns a couple of...
Your eject problem will be one of three things. 1- the gears for the eject mechanism have shifted and not making contact with each other. You can fix this by realigning the gears. 2- The gears are stripped and need replaced. 3- there is a small plastic pin that releases the cassette bay. check to see if this pin is broken. If so, then you will need to replace the pin or the gear the pin is attached to. With this being an older model, parts will be extremely hard to find. Let's hope that the gears are just misaligned.
Aug 05, 2008 | Sanyo Cameras
I have old tapes from an old camcorder Sanyo VM-D66P that I want to capture to my pc, how do I do this?
There are several ways of converting your tapes to a digital format.
1. By routing it through a DV camcorder with AV-input (these are increasingly rare though. (using firewire).
2. By using a device like this, which converts to DV. (also connects via firewire). http://www.dv247.com/invt/23453
3. By using a device which captures to MPEG2.
The cheapest way is option 3, but it requires a working camcorder. You should purchase a device similar to this: http://www.avforums.com/forums/attachments/camcorders-video-editing/85846d1216145397-camcorder-computer-easycap.jpg
If you don't have your camcorder anymore, or it isn't functioning, you should try to get a second-hand 8mm camcorder with firewire. This way you are able to directly convert your tapes to your pc.
If you can't find a firewire camcorder you could just settle with a good functioning 8mm camcorder but you will have to buy a capture device as mentioned above.
Jun 06, 2010 | Sanyo Video Cameras
MY SANYO CAMERA MODEL 8MM VM-d66P SHOWS A WHITE
IF YOU CANT GET THIS FIXED CAN I BUY IT FROM YOU AS I NEED A 8MM CAMERA TO CONVERT MY TAPES TO DVD AS MY OLD 8MM CAMCORDER WONT PLAY.OR DOES ANYONE HAVE ONE I COULD BUY CHEAP OR BORROW...IN MELBOURNE AUSTRALIA...CHEERS JB
Jan 09, 2010 | Sanyo VM-D6 Camcorder
Cannot play them
Oh boy the 8mm tape will work in a hi 8 playback but the resolution will be just 8mm
Just the same if you have hi 8mm tapes you can record on then with regular 8mm cameras.
Jul 26, 2009 | Sanyo VM-D6 Camcorder
8mm tape got stucked in an hitachi camcorder
TAPE IS JAMED NEED TO TAKE IT APART A REMOVED MANUALLY
May 20, 2008 | Sony 8mm Stantard Grade 120 Minute...
Canon UC1 8mm video camcorder
No solution..... but eager to know where one can get the battery packs and charger fir this camcorder (UC1) A 8 mm videotape is stuck within the camera housing and can not be ejected...No battery and charger available..
Where are those battery packs available f.i." SUNPAK RB-E77MF 6V 1700 mA ??
I would highly appreciate your advice
Thanks in advance
J.van Bochove
e-mail: jvbochove@onenet.an
Jan 05, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
Video Cameras Logo
378 people viewed this question
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
