Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water dispenser leaks of my whirlpool refrigerator gs6shaxk b01
Water leaks only when we use the water. I could not find any srews inside or out side to remove the water dispenser to find the proble and then order the right paarts to repair the problem.
  • r_salani Jan 07, 2009
    Thanks for your solution. I found screws under the water collecting tray and removed the front plate. However, I ccould not remove the nozzle and tube, which I suspect is leaking. Any advice please? Should I disconnect the wiring? Also when I open the door the water dispenser does not operate. How can I check the exact spot of leaking. Is there a way to make dispenser operate when door is open? Thanks again.
  • nenaden Jan 10, 2009
    I have the same problem. I am assuming there is a valve somewhere that is not closing completely or is worn, but I am unsure how to locate it.
On the bottom of the faceplate there should be two small pry spots to remove faceplate. once the faceplate is removed you should have acess to the inside.
Posted on Dec 31, 2008
My whirlpool gold ice dispenser leaks water and creates icicles inside, what could this be?
bad water valve or the ice maker is cracked,if the valve doesn't work correctly it can let to much water into the ice maker causing it to overflow or the ice maker has a crack in it and the water leaks out.
Jan 23, 2013 | Whirlpool GS6NBEXR Side by Side...
Constant, slow leak from water dispenser on whirlpool refrigerator
you might need to replace the bottom section and spare parts should be available readily online. I had a slow leak on my samsung side by side and it was resolved once i bought a new part...Hope this is of some use but not an expert.....
Jan 02, 2013 | Whirlpool Refrigerators
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Ice maker leaking water through ice dispenser in the door.
you have double trouble it so . water leaking through door is the foutain and if its the ice maker then the inside of freezer would be flooded . so change the water valve its a dual valve and this fixes both sides . but i thnk ou have only on side leaking .. mm
Aug 17, 2010 | Whirlpool 21.7 cu. ft. Side-by-Side...
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
1,218 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
