Question about Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range
BELLING SANDRINGHAM 100 DF ALL OVENS NOT WORKING
Help, I used all my ovens/grills on the Sandringham 100 yesterday and the whole lot lost power and will not turn back on. The trip switch didn't trip and there was still power to the wall socket. It's just one month out of warrantly. I could scream. Can anyone help me????
  • 906 Answers
Good day,
hope this link below will solve your problem.
ovens
Posted on Aug 03, 2010
Oven and grill stop working no indication lights even turn on
Hello,if the whole oven longer then first see if there is power if it is to supply the fuse, which can be measured volt meter but maybe there will be one more heat than it is to heat that I helped, maybe would help if I could type.
May 02, 2013 | Bosch HBL 435 Stainless Steel Electric...
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
The grill on our belling oven has never worked since we bought our house. Any ideas?
Could be the switch, the element that ate faulty or it could be the fuse that has blown. With a volt meter, check that there is power at the element with the oven set to grill. If there is power that rules out the switch and the fuse. If there is no power, check first the fuse and then look at replacing the switch. If there is power at the element, switch off the mains and do a continuity test on the element to check if that is faulty.
Feb 06, 2011 | Belling Ovens
Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Please rate my solution.
Thankyou.
Feb 02, 2010 | Belling XOU592 / XOU593 Electric Double...
Belling country chef 100 df oven to right clock and ignition not working
It could also be the micro temp thermal fuse which cost about a £2.00 to replace and has to be fitted with crimps (NOT SOLDER). This is located behind the large back panel and should be replaced by a qualified Electrician.
Apr 28, 2009 | Belling DB2 Dual Fuel (Electric and Gas)...
How do I find the model number on belling synergie oven?
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
Mar 23, 2009 | Belling XOU174 Electric Single Oven
Belling oven
you will have to replace the main oven element...
May 03, 2008 | Belling XOU252 Electric Single Oven
Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range Logo
254 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
