Question about Compaq Presario 5000 PC Desktop
I need to replace my ide drive on my compaq presario 5000 but i cant seem to locate it could you help me out?
  • 728 Answers
HI,
ON the 5000 series there are two possibly three ide drives on the machine. Once you have the front bezel off, and the remove the side panel, you will find near the top of the machine the ide cdrom drive, and possible another cdrom or tape backup ide drive. Below those one or two drives is your hard drive (ide). To remove them, you will need to unplug the power cable, which is the white plastic plug with the multiple color wires going into it. Then remove the grey wide cable which is your ide cable. Do not remove the other end of the cable from the motherboard. Remove which every ide drive you want to replace and install the new one, and be sure to hook up the ide cable and power supply back into the same positions as before.
Thanks
Mark
Posted on Dec 31, 2008
I have a compaq presario CQ80 lap top. I am getting an error that the HDD needs to be replaced. It has a 160 gb hdd, and I would like to replace it with something bigger. I cant seem to find any ac
the only thing you need to know is if it is a sata or ide hard drive (if you look at the end of the drive if it has a lot of little holes it's an ide) then shop for whatever size drive you want i.e 250GB 2.5" hard drive. Because it's for a laptop it will have to be a 2.5" hard drive.
Dec 14, 2012 | Compaq Presario Notebook
I have compaq presario 5000 and I'm having problem
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Oct 21, 2011 | Compaq Computers & Internet
I need a repait manual or wiring diagram to make sure my ribbon wires are in the correct location.
there are no ribbon cables in that desktop... there are only ide cables.. and they only fit in one place.. the ide slot.. doesn't matter which one you plug the devices in to
Mar 31, 2011 | Compaq Presario 5000 PC Desktop
Compaq presario sr1800nx won't turn on
Check the jumper settings on the DVDRW. Depending on IDE location, you need to set the jumpers accordingly. If you have the main system hard drive on the same IDE channel as the DVDRW, set the jumpers on the DVDRW to slave, if that don't work, set them to Cable Select. I'm assuming it's an IDE drive and not SATA.
Dec 30, 2009 | Compaq Presario SR1800NX Desktop PC
40GB WD protege IDE WD400EB hard drive went down. I want to replace it with faster and larger drive. Please advise.
Hi there
I think you can put up to 200BG IDE hard drive in that desktop, i recommend seagate hard drives as they come with a 5 year guarantee and can run at 7500rpm.
Good luck and thanks for using Fixya!!!
Feb 19, 2009 | Compaq Presario 5000 PC Desktop
Compaq 5000 how to change hard drive
is a long procedure ......
if u available online than i can help u by telling u d procedure.....
i cant tell u now becaz if i tell u procedure n dere is some error occurs then hw could u solve it....so it is needed to be online both of them....
Jun 22, 2008 | Compaq Presario 5000 PC Desktop
Ide issues
create partiion and format hard drive.
Mar 06, 2008 | Compaq Presario 5000 PC Desktop
Compaq presario dessktop 5000 series 5330US model#470019-713,Intel Pentium 4
Here is a link which supplys all needed internal parts for you specific computer...
http://www.impactcomputers.com/compaq-presario-5500-desktop-parts-internal-parts-and-assemblies.html
Feb 25, 2008 | Compaq Presario 5000 PC Desktop
Replace CD-Rom Drive
solution: open front blue magnetic case door, look on either side of the power button, there are finger holes in the other blue cover.
lift out from bottom to top. this cover comes off, not the whole
case. inside find tabs next to cd drive, squeeze and pull out. note: the side sliders were they come out, they will come off the
cd drive when removed. it is easier to replace the top drive by removing the bottom drive, put in the top half way, then put bottom back in half way and slide them in together.
voice of experience. hope this helps
Jan 12, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
95 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
