Question about GE WCVH6260F Front Load Washer
Reseting of spin / wash cycle
Our GE WCVH6600 constantly resets its spin / wash cycle. Techs. have come to the house and have suggested leveling the unit and making certain that each load contains similar articles. A single load has taken up to nearly 2 hours. Any suggestions.
    Sergeant:
  • 311 Answers
Dont know how old, but get those techs back to fix ,call their boss ,call GE and complain
Posted on Dec 31, 2008
Why does my GE washer get stuck in Drain cycle??
for one G.E not a good choice mostly junk. the timer may indeed be bad if its sticking at 1 point and u can move it manually?
Feb 27, 2015 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
WCVH6600 pausing in cycle, long cycle time
Could be heater burnt out and taking long time to get up yo temperature or sinply defaulting to running cold after a given programmed time lapse.
Dec 09, 2013 | GE Washing Machines
My ge washer is not spinning just sits there and hums on spin cycle. any suggestions?
Check the voltage on the spin cycle with a multimeter. If there is low power from the controller then the controller is faulty. Check the voltage available in the wash cycle. Also check the capacitor to the motor and the belt and rotor of the washer. when tested manually the movement should be free. If not reset the shaft and drive.
May 09, 2011 | GE WBSR3140DW Top Load Washer
When washer done rinse cycle lights flash and washer stops doesn't rinse and spin
Hello
Try reseting the machine.Unplug power for 60 seconds.
Plug back in,then turn knob to reset.Then try another load of wash or finish the one that is stuck before rince cycle.
It is possible the control timer is going bad.
Aug 29, 2010 | GE Washing Machines
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
GE top loading washing machine (WBSE2090A0WW) stops spinning
it sounds like you know how to remove the frount panal,remove the frount panal.put unit in spin,look to see if belt is turning,if it is not than you have a bad cluch.
Dec 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE WHDRR418 top load washer won't spin at high speed; the washer does the complete cycle, and agitates in both directions and does physically spin, but it will not go into the 'high speed' spin that...
we can eliminate the motor and the switch since that part is working. sound like your timer might be faulty, timer make everything work in persistence cycles, if its goes bad sometime it tend to jump/skip cycles.
Jul 21, 2009 | GE WSXH208A Front Load Washer
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Constant resetting
it may have a blocked up pump so keeps trying to spin out water.But your under warrenty.call GE they will send some one out to fix that for you
Dec 31, 2008 | GE WCVH6260F Front Load Washer
GE Washer top-load WLDSR416FOWC
Actually, I think I do remember having one do this before, and I believe on these GE models the spin cycle goes through the water level switch, so if your water level switch is sticking, then it won't spin, thinking its still full of water.
Here's the water level pressure switch for your model:
Manufacturer part#WH12X10065 is RepairClinic item#2205
don't forget to rate me in main page,it is the only way i get paid for my works..
Jul 23, 2008 | GE WDSR2080D Top Load Washer
GE WCVH6260F Front Load Washer Logo
191 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
