Question about PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames
Pandigital 7" photo frame won't play avi files
I am trying to take a video file made with my Kodak Easyshare Z7121S camera and convert it to avi format so that it will play on my Pandigital 7" digital photo frame. (The camera records the video file in mov format) I have used several different file converter programs including ASV converter, and the conversion goes well, but the photo frame says avi not supported, but according to the user manuel motion jpeg (AVI) is the only format it will read.
Does any one know of a way to get an avi video clip to play on the Pandigital 7" digital photo frame?
  • 1 more comment
  • jnarayana Jan 18, 2009
    Even I am facing the same problem. I have PAN111-B pandigital frame.
  • Anonymous Feb 03, 2009
    ive tried several converters none worked all the way ive been able to get video converting with alive video converter using { apple quick times video (*.mov) }
  • Bobby
    Bobby Nov 10, 2013
    I Use Cmtasiastudio torecord the PPT,then Produced it as a mpg4 (I even got to edit and add some cool effects). The I used ConverterLite to convert the file into an AVI file. It plays beautifully on my Pandigital Frame now!
I made my pandigital 8" touch screen videos work by:
used MOVAVI software to convert my .mov video to avi
then had a polarid mp3 player which had a simple software to convert to the polarid mp3's video files. large's video selection was 320x240.
that worked.
RA
Posted on Dec 28, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
Hello, please try nidesoft converter, here is the link
http://www.nidesoft.com/video-converter.html
Posted on Sep 01, 2010
2 Suggested Answers
bjamieson083
  • 15 Answers
SOURCE: Pandigital 7" photo frame won't play video
It appears that the Pandigital 7" frame (7001W01) can only play back videos encoded with the Motion JPEG A codec. The instructions do not articulate this properly and only inform you to use .avi and that video from other sources other than your camera may not be supported. Problem is, not all cameras use MJPEG A to compress the footage. But this workflow will allow you to make any type of video playback on the frame.
Just to clarify - .AVI is not a video format. It's a wrapper that holds the video. The same goes for things like .MOV or .OGM. These are only wrappers. So for Pandigital to say the frame supports ".AVI" does not explain much. It does not support codecs like DiVX or H.264, for example.
At any rate - your best option to get video to play back on these frames is to download MPEGStreamclip from the developer Squared5 (it's free) and use it to convert your videos to Motion JPEG A avi's. I'm not sure about Fixya's linking policy, but you can easily search google for "MPEGstreamclip" and find Squared5's website.
MPEGstreamclip is available for both Mac and PC platforms.
1. Once you have the software, open it and go to FILE -> OPEN FILES and select the video you would like to encode. It will load in the viewer.
2. Next, go to FILE -> EXPORT TO AVI. This will open your compression options for an .AVI
3. The first option you are offered is "Compressor" - this is the most important. Click on the arrow and scan through until you find "Apple Motion JPEG A" Click it to select this as your compression codec.
4. Leave the quality setting at 50% I found that the Pandigital Frame will choke on larger files. We're going to be shooting for a file size of appx 300mb for 3-4mins of video in order to keep things moving. Video data is very large, and the fact is is that this frame is not meant to playback very data intensive files. So you will be best off playing it safe and keeping your bitrate (kbps) low.
5. If your video file has sound, leave your Sound setting at MP3 / Stereo / Auto, but drop the bitrate to 96kbps or 128kbps. Again, we're trying to keep file sizes down and the audio out of the Frame is not great to begin with. If you must have audio, keep it low (96kbps or 128kbps) If your file does not have sound, click the MP3 drop down menu and select "No Sound"
6. Choose your frame size. If your video is 16:9 (rectangle) select 854x480 (16:9) if it is 4:3 (square) select 640x480 (4:3) - Please note, if you are using 4:3 videos, your video will have black bars on both sides of the frame. This is the nature of video aspect ratios. Aside from magnifying your video to fit a 16:9 screen, you will need to have black bars.
7. Check the box "Deinterlace video"
8. Ignore the other options.
Click "Make AVI" and the video will begin to be compressed. As I mentioned, video is a very data intensive process and compression can take time depending on the length and size of the original video. I tested this on files that were 3 minutes and 3 GB to begin with on a MacBook Pro and got the file down to 300mb in 15 minutes using these settings. I repeated this on a PC running Windows XP and had the same experience. Your times and sizes will vary.
I do not recommend trying to playback files over 700mb on the frame. My first attempt gave me a 1GB file that froze the frame when it tried to playback.
In all likelihood you will need to put the video file on a SD card or use a USB thumbdrive as the internal memory of the frame is 128mb.
Good luck! And don't be afraid to try other settings in MPEGstreamclip to better render your videos for the frame. Video compression is all about trial and error :)
Posted on Jan 03, 2009
My AVI video file won't play on the Pandigital 12"
As I know, pandigital supports mp4 video, not avi video. You can follow this guide to convert your avi video to mp4 video, and then transfer the video to your pandigital.
http://www.reviewstown.com/how-to-convert-avi-mp4-wmv-mkv-flv-mpg-youtube-video.html
Hope it helps. Feel free to email me if you need further help.
Nov 10, 2013 | Memorex Mi8000BLK iFlip 8.4" Portable...
Pandigital 7" Digital Photo Frame-MJPEG .AVI "Format not supported"?? Can anyone help me to understand why my videos will NOT play on this device? I followed step-by-step instructions which were posted...
You need to convert the video format with an excellent video converter,
Video Download Studio can help you with this very well.
Get a free trial from http://www.downloadvideos-convert.com/download-videos-music
Hope it can help you more or less!
Sep 26, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Merge videos , what can i do?
Use the windows movie maker in Windows 7 (download it) or Vista and stitch the videos together into a single file. Then upload the video to youtube.com or facebook.com. Got it?
Jul 23, 2010 | Kodak Zi6 Flash Media Camcorder
I bought an 8" Pandigital 8051 model from Costco and it works fine with photos, but for vidoes it says the unsupported video format. I tried converting my JVC .MOD file to AVI using MPEGStream as...
i think in this case,
you should convert the format of your video with an excellent convert,
i want to recommend you have a trial of Video Download Studio.
i have used it for a long time,it proves worked very well.
it can download, convert,trim ,crop and edit your video with high quality.
i believe it can meet all your requirement. you will like it.
why not get a free trial from http://www.downloadvideos-convert.com/download-videos-music
hope it can help you more or less!
May 29, 2010 | PANDIGITAL 8.0" Digital Photo Frame...
Can video file format on Kodak M1063 be .AVI
What u need is a video converter.
Try Pavtube Video Converter(http://www.pavtube.com/video_converter/)
It can convert mov to avi without quality loss.
easy to use, reasonable conversion speed.
Apr 19, 2010 | Kodak EASYSHARE M1063 Digital Camera
My Kodak M820 8
yes avi should play on that.. but i think that kind of device(frame) is like some of the mp4s that includes avi in the features but will have problems playing avi type of files.... ... i dunno if this is useful coz i dont think i have the answers to correct it... maybe u can just convert the files in other filetype that your frame can read....
i read this from wikipedia
The AVI container has no native support for modern MPEG-4 features like B-Frames. Hacks are sometimes used to enable modern MPEG-4 features and subtitles, however, this is the source of playback incompatibilities.
AVI files do not contain pixel aspect ratio information. Microsoft confirms that "many players, including Windows Media Player, render all AVI files with square pixels. Therefore, the frame appears stretched or squeezed horizontally when the file is played back."[1] There are other video container formats that allow irregular shaped pixels.
More modern container formats (such as QuickTime, Matroska, Ogg and MP4) offer more flexibility, however, projects based on the FFmpeg project, including ffdshow, MPlayer, xine, and VLC media player, have solved most problems with viewing AVI format video files.
pls do update me if you've resolve the problem
Sep 13, 2009 | Kodak Digital Picture Frame
Trying to put I-DVD movie on my digital photo frame
Re-edit the movies and pictures following the formats below: Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
Apr 02, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Dec 17, 2008 | PANDIGITAL 7" Digital Photo Frame With...
PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames Logo
2,165 people viewed this question
Top PANDIGITAL Audio Players & Recorders Experts
Tom Chichester
Greg Ulan
d3yavu3
Are you a PANDIGITAL Audio Player and Recorder Expert? Answer questions, earn points and help others
