Question about Epson Perfection V700 PHOTO Flatbed Scanner
When I scan colour slides the image gets cropped
I lose one side of the slide. Is there a way to adjust the location of the scanned image. Is there some sort of calibration.
  • gdupa Mar 03, 2009
    I have the same problem. Also, the slides do not scan in the same order as they are in the holder.
    I called technical support and they have no answers. I have an Apple computer, so they told me to try it with a PC. Same problem.
    It is still under warranty, so they suggested I take it in for repair.
  • 35 Answers
Uncheck the option that says "Thumbnail" and draw individual marquees for the area on the slide you want to scan. Not very elegant but it works.
Posted on Jun 14, 2009
Hi, I have Canon Pixma MP270. IS it possible to scan photo negatives and change to colour prints. thanks. Blair
A multi-purpose printer scanner cannot scan negatives or slides.
You need a slide scanner or a flatbed scanner that is capable of scanning negatives and slides. Not all flatbed scanners are capable of scanning slides and negatives.
Sep 27, 2010 | Computers & Internet
My scanner sometimes crops a particular slide but not others. Some scan ok. What is going on?
Be sure to put the slide in the holder in the proper direction. The opening in the slide holder is rectangular, not square like the slide. If you place the slide in the holder horizontally and the holder window is vertical, it will crop off the sides of your picture.
Jul 20, 2010 | Plustek OpticFilm 7200 Film Scanner
How to scan slides to photos to hard drive using canon canoscan 8400f
Your scanner came with some software inside the box. If this is a second hand scanner with no additional software download the drivers from www.canon.com and run the software accordingly.
Mac os X does not require this process. connect the scanner to your machine and simply load the slides in the tray scanner and use the application "IMAGE CAPTURE" located in local_disk/applications/
The pictures automatically load and you select to crop or scan as is.
Later the image will appear on the desktop upon completion of scan.
For windows: I made you a link for your convenience: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=10242
Nov 07, 2009 | Electronics - Others
Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
Jul 03, 2009 | Epson Perfection V350 Flatbed Scanner
Cant scan 4cm x 4xm slides
The mounted slide scanning option is set for scanning 35mm mounted slides (24mm x 36mm). As far as I know there is no way to change this setting. You may want to try using the film scan option, do a preview scan, and then crop each individual slide for the final scan.
Oct 16, 2008 | Canon MP970 Photo All-In-One InkJet...
Scanned 35mm slide comes out as rectangle with dark edges
I've not ever seen "square" 35mm slides. By definition they are a rectangular positive film in an outer square "mount".
If you have a truly square piece of film then it is not a 35mm slide. You may have to use settings other than those for a 35mm film but these would be I don't know.
When were they taken (approximately)? What brand of film? Are they in a cardboard "mount?
Aug 01, 2008 | Epson Perfection 4490 Office Flatbed...
Scanning Problem
Scanned image is unsatisfactorily cropped
You can turn auto-cropping off or adjust how the image is cropped.
To turn auto-cropping off:
From your desktop, double-click the Lexmark X6100 Series
All-In-One Center
icon.
The All-In-One Main Page appears.
2 Click See More Scan Settings.
3 Click Display Advanced Scan Settings.
4 Select the Scan tab.
5 Click Select area to be scanned, and then select a size from the
drop-down menu.
6 Click OK.
To adjust how the image is cropped:
All-In-One Center
icon.
4 Click the Scan tab.
5 Select Auto-crop the scanned item.
6 Slide the Tolerance bar to the left to crop less or to the right to crop
more.
7 Click OK.
Dec 06, 2007 | Lexmark X6170 All-In-One InkJet Printer
Scanner
There is glass platen and on its sides you can see the markings to place various paper sizes. Just follow them as per your paper size.
Oct 05, 2007 | Epson Perfection 1240U Flatbed Scanner
Unable to use film adaptor
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
1) In the program you are working from, begin the scanning process. If working in full auto mode, as the scan begins you will see a message that reads TO CANCEL SCANNING IN FULL AUTO MODE AND SWITCH TO MANUAL MODE, CLICK CANCEL. At this point, click CANCEL, then MANUAL MODE.
2) You will now see all Epson Twain settings displayed. If the scanner has not previewed automatically, click the full page preview button (icon of a paper with one corner folded down).
3) Ensure the settings on the right hand side of the Twain are correct. For example, the DOCUMENT SOURCE for transparencies must be either TPU: COLOR NEGATIVE FILM, TPU: MONOCHROME NEG or TPU: POSITIVE FILM.
FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes. (If you are scanning a black and white slide in true colors, choose TPU: POSITIVE FILM as the DOCUMENT SOURCE and BLACK AND WHITE PHOTO as the IMAGE TYPE.)
If the DOCUMENT SOURCE is flatbed, the scanner will not activate the backlight in the transparency unit. If the DOCUMENT SOURCE is greyed out and you cannot select a TPU option, close the twain, reseat the power/communication cable connecting flatbed to TPU, then re-open the twain and try again.
4) Ensure the other twain settings are correct for the type of scan you are doing.
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no guidelines on this; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing an AUTOMATIC THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, click the CONFIGURATION button and uncheck AUTOMATIC THUMBNAIL PREVIEW FOR FILM, then OK, and try the PREVIEW button (page with corner folded down) again.
In this mode, you will have to manually marquee or crop the slides you wish to scan. Use the left mouse button to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process (manually crop then scan) for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Aug 16, 2007 | Epson Perfection 1200 Photo Flatbed...
Epson Perfection V700 PHOTO Flatbed Scanner Logo
267 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
