Question about Kenmore 22422 Top Load Washer
Washer is making a grinding noise. It want spin or agitate.
I have a Kenmore Series 70 top loading washing machine model number 110.20702990. It will not agitate or spin, I took the agitator off and all but one of the dog ears were broken but it did not fix the problem.
  • 2 more comments
  • Anonymous Jan 03, 2009
    70 series wont spin or agitate coupler good grinding noise
  • rob289c Jan 06, 2009
    I have the same problem...just started today. My coupler is good; I'm thinking gearbox bad. Difficult to repalce?
  • waldropr Jan 07, 2009
    Would that be the Drive Motor you are referint to?
  • musicole6 Mar 12, 2009
    same problem, same model. Any help?!
  • 107 Answers
Coupler between the motor and gearcase is broken...Remove end caps and phillips screws from console. Pull console and flip up..Unplug lid switch and remove gold looking clips on both sides. (push screwdriver strait down and press away from you)..Pull cabinet towards you and remove. Pump is in middle of front by floor..Remove 2 clips with flat head and pull off. ( leave hoses on pump). Remove 2 1/4" screws and remove motor clips with flathead. Motor will fall so hold hand under it. Check plastic and rubber coupler between motor shaft and trans. I guarantee, its broken or worn out..
Posted on Mar 13, 2009
    Problem Solver:
  • 7 Answers
Sounds like ur shaft is stripped motors about 100 bucks ur call prob better get a new one
Posted on Jan 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: 70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Posted on Mar 27, 2009
Maytag317
  • 1136 Answers
SOURCE: replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 03, 2009
SOURCE: Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Posted on Jul 04, 2009
  • 1937 Answers
SOURCE: dual action kenmore 70 series washer need to remove agitator
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Posted on Nov 06, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 70 series washer fills w/H20, but doesn't agitate or spin
Fix it. Very easy fix and the part is not expensive. What you have is a direct drive motor. For ease of maintenance the machine is made in a way which makes it possible to service it in place without having to move it. You flip the controls up and pop the retaining clips in back, unplug the lid switch harness and tip the case towards you an out of the way. You can now access the pump, motor, and that pesky drive coupling. These do simply wear out but they usually will go if a comforter is washed in it or low water big load scenario.ea74271.jpg
I have videos repair manual,parts locaters and repair photos: HERE
Posted on Feb 14, 2010
Testimonial: "Thank you for the EXCELLENT & QUICK solution! Your repair suggestion along with instructions worked perfectly & saved us hundreds of $$! "
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Mar 27, 2009 | Kenmore 22422 Top Load Washer
My washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Jan 19, 2009 | Kenmore 24932 Top Load Washer
Kenmore washer will not agitate or spin & makes grinding noise
CHECK THE MOTOR coupler located between the motor and then transmission this will be a good place to start if you lean back the washer and look from the bottom you will see a thing between the motor and the tranny that looks like a oreo cookie check and see if that is broken in any way
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
272 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
