Question about Bosch 24 in. SHU43 Built-in Dishwasher
1997 bosh SMU 2000 dishwasher,The light comes on and you can hear
The light comes on and you can hear timer but nothing happens even when turning dial.I am pretty handy and i have unit out and have been checking for power but havent figured it out .Any help would be appreciated.
  • 1 more comment
  • electra6 Jan 01, 2009
    It is obvious that this guy is not familiar with this actual model as it does not have a belt ,The valve turning on the water doesnt activate . Im not sure if its soposed to ge power when turned on ,but it doesnt.
    how do i test to make sure it is the timer outside of purchasing one?
  • electra6 Jan 06, 2009
    we figured out it was the timer, thank you
    Sergeant:
  • 311 Answers
Well sence you are handy its power in thru the door switches then power will leave at some place from the timer to the motor.your wiring diagram would have that info.if you dont google your model or brand and see what comes up .it has be my pasted experance that the boards went bad not motors.but you may have some switches to go thru also[ie.door etc] thanks for using fixya
Posted on Jan 01, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
I too am not familiar with your model as either they have a different model number or a version/variation of the Bosch SMU2000 in my country.
Still, with your indulgence, a couple of ideas you may want to consider, explore and check:
  • door switch - as the name implies senses the condition of the door which is a pre-requisite prior to activation of anything else of the timer board. The dorr maybe physically closed by the door latch but electrically still open either because the door switch is defective or the tab engaging the door switch is mis-alignment, defective or missing. In some Bosch models, the door switch is a small red plastic button covered by a translucent piece of another plastic;
  • the timer itself (likely) - unfortunately no easy test procedure;
  • there would be a tech sheet with a wiring diagram somewhere on the machine. Often found in the bottom/kick panel. The wiring diagram culd be reference to trace the current flow in the circuitry.
Good luck and Thank you for using FixYa. Happy New Year.
    President:
  • 2,110 Answers
Sounds like the timer is bad. The timer motor is not replaceable and you have to order the whole timer.
- The part number for the timer is AP2802778
  • 1,800 Answers
  • Unjam the motor
  • Unjam the pump
  • Test the motor
  • Test the motor start relay
  • Check the drive belt
Posted on Dec 31, 2008
Hi My Bosh dishwasher is model SMU 7056UC The water is not out of the bottom of the unit, when the cycle is complete it is still cloudy. What do we do? What part number do we need for the door seal...
Hi
either your dishwasher has a blocked filter or a blocked water outlet. Some dishwashers will reset if you can unblock the pump or outlet where it goes to waste. You will need to bail out the water first, then pull out all the filters and clean them and if you can check nothing is jambing the impeller in the pump. Normally toothpicks, chicken bones etc. Sometimes it is blocked where it connects to the s bend under the sink. Just undo it and check it is clear and then reconnect it.
If you clear it and it does not restart you will need a serviceman
cheers
Jan 07, 2011 | Bosch Dishwashers
Everything works...cam timer moves drain opens but wash motor does not turn on
could possibly be a bad micro switch, a bad contactor or even a bad capacaitor on the motor
Dec 22, 2009 | Jackson 25 in. Conserver XL Free-standing...
Cycle doesnt stop
STUCK TIMER MANUALLY ADVANCE TIMER THEY HAVE NOT MADE THE SMU MACHINE FOR OVER 12 YRS MIGHT BE TIME TO REPLACE MACHINE OR GET A QUALIFIED TECH TO LOOK AT
Jul 20, 2009 | Bosch Dishwashers
Dishwasher won't fill on start
Check the following to address this issue.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Cleaning Cycle not Starting
Please provide the model number and the approximate age of the dishwasher.
If this diswasher uses a turning dial to select the cycle, which turns as the dishwasher progresses, I strongly suspect that this timer has failed and needs replacement. Especially since the soap door never opens. Does the dishwasher drain during and at the end of the full cycle?
Mar 29, 2009 | GE Dishwashers
Dishwasher does not turn on
I believe if you look closly, you will see the G is actually a Q. So the valid model number is DU980QPDQ3.
This model has a controller module (CNTRL-ELEC $188.00 US) that includes the buttons in the door panel. The logic/control begins there and communicated with the display and the timer/timer motor.
Depending on the age of the unit, you need to choose between repair or replacement. Good Luck!
Mar 29, 2009 | Whirlpool 24 in. DU980QPD Built-in...
Dish washer not working, lights come on but nothing happens, will not drain water that is in there either.
flooding the sink won't have anything to do with the dishwasher.unless the check valve on the dishwasher got stuck closed. Can you hear the pump come on?
Oct 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Washer not cycling
I manually turned the impeller on the motor and "broke it loose". I found out if you don't use the washer for even a small period of time the motor may do this.
Jul 25, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
No water on wash cycle
YES YOU ARE RIGHT TIMER COULD BE FAULTY OR WATER INLET SOLENOID COULD ALSO BE BAD
Feb 02, 2008 | Dishwashers
Bosch 24 in. SHU43 Built-in Dishwasher Logo
67 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
