Question about GE WCVH6260F Front Load Washer
Constant resetting Our 2 week old GE WCVH6600 washer keeps on resetting its spin and wash cycle due to an "inbalanced load". We've had techs. come to the house to examine and suggested leveling the the unit and making certain that each load contains similar articles. One load can take up to nearly 2 hours. Does anyone have a fix or have had the same problem?
    Sergeant:
  • 311 Answers
It may have a blocked up pump so keeps trying to spin out water.But your under warrenty.call GE they will send some one out to fix that for you
Posted on Dec 31, 2008
Constant out of balance on washer
Check the inter tub ring you should hear water when you spin it by hand
if you dont hear water replace the spin tub balnce ring it must be cracked or has a hole in it and leaked out the fluid this is a counter balancer when it gows into the spin cycle
h Tech AL Wojo
Apr 01, 2013 | Maytag Bravos MTW6600T Top Load Washer
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
GE WHDRR418 top load washer won't spin at high speed; the washer does the complete cycle, and agitates in both directions and does physically spin, but it will not go into the 'high speed' spin that...
we can eliminate the motor and the switch since that part is working. sound like your timer might be faulty, timer make everything work in persistence cycles, if its goes bad sometime it tend to jump/skip cycles.
Jul 21, 2009 | GE WSXH208A Front Load Washer
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Wash/soak cycles will not work
Just cycled thru the switch several times and all of a sudden today it started working on the wash cycles
Jan 07, 2009 | GE WDSR2080D Top Load Washer
Reseting of spin / wash cycle
dont know how old, but get those techs back to fix ,call their boss ,call GE and complain
Dec 31, 2008 | GE WCVH6260F Front Load Washer
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Extremely Load spin cycle
Mine was doing this and my husband tightened the huge bolt on the back of the drum. This is where the belt attaches. Evidently this bolt when loose can cause that outrageous sound.
Mar 03, 2008 | GE WSXH208A Front Load Washer
GE WCVH6260F Front Load Washer Logo
191 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
