Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
Hoover steamvac spinbrush leaks bottom when attaching cleaning tool
Whenever I attach the cleaning tool, the cleaning solution leaks from the bottom. When I turn the machine on, it spays out the side too. The machine works fine if I am not using the tool. When I am done using the tool, I have to run the vac over the carpet to **** up the leak. Not sure what is going on. Please help.
  • Beth Kantzler Nov 13, 2012
    I have had 3 and they all leak as soon as you put the water tank on I've tried every thing it leaks even when I'm cleaning the carpet, BS to repair something that is NEW!tank on I've tried everg
reddevil6
  • 1673 Answers
SOURCE: Leaking Hoover Steamvac
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Posted on Mar 29, 2008
reddevil6
  • 1673 Answers
SOURCE: Water leaking out bottom with hose attached
The water hose plugs into the solution valve-pressure on the side of the noozle(bottom). There may be a water line that has come loose there, you will have to take the top off to get to it.
Posted on Apr 20, 2008
SOURCE: Clean water coming out of sides
Hoover SteamVac Ultra (model F5883-900) Threw it away, and had to buy a new machine. Sorry, but I found it more difficult to deal with the housing unit on the machine and just couldn't deal with it anymore. I hope you have better luck than I did with it. I couldn't find ANY help on ANY web sites for this model, just too old I guess.
Posted on Jul 28, 2008
impinokio
  • 7 Answers
SOURCE: my steamvac leaks from the clean water tank
you have either a cracked housing, or a valve is stuck open. if you can spray a small amount of wd49 into the valve, and work it a little, youmay be able to dislodge whateverdeposits have built up in there.
Posted on Jun 21, 2009
  • 240 Answers
SOURCE: my Hoover steam vac dual
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
Posted on May 21, 2011
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Why is water pouring out the bottom when I try to use upholstery attachment?
On many hoover models the hose attaches to the vacuum and is held on by a clip on the hose assembly. There may be some damage to your hose or the place where it attaches to the machine. Inspect these areas trying to locate the point of the leak.
Feb 25, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
I took my nozzle apart on my hoover steam vac because it leaked water all the time, now I cannot get the back together
The Hoover SteamVac is an upright, self-contained carpetcleaning machine. The machine features five rotating brushes and on-boardstorage for a hand-held upholstery tool with an 8-foot hose. But itis not that much difficult to re-attach the Hoover SteamVac nozzle. Here, a weblink, with full procedure and diagrams, which will help you to re-attach iteasily - http://hoover.com/file/624/. Hope this will help you. Good Luck.
Aug 18, 2011 | Vacuums
SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My steamvac leaks from the clean water tank
try to look for small holes or cracks and even the tank.use clamps to make sure your hose is firmly attached.
Jun 21, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Using stair attachment, ++water leaks onto floor under the unit;
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool properly. Follow
these steps:
1. Attach tool to hose and turn the deep
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
Feb 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
NO DIRECTIONS FOR HOW TO ATTACH AND USE STAIR TOOL FOR MY HOOVER
Here is the link to Hoover's manuals. I could not locate a model F5900-900 But i believe it is F5914-900. Please verify before downloading manual by checking the serial number stick for a model. Its silver and should be on the back or bottom.
Dec 09, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Leaking from bottom
It is the steamvac pump that is bad. When you fill up the tank with solutions, even though it is not running the solution leaks out, and when you turn it on it sprays up and out the sides etc. Also the attachment doen't work either, no solutions comes out. Apparently the float sticks in this. My husband fixed it once, and now he can't, need a new part. Options are take it to a hoover service dealer, or I found 2 place online that sell the part. One is http://buyitnow64.stores.yahoo.net/hostrepufor5.html and the other is http://www.sweeper-city.com/ho5brstpu.html, this site if you look at different size pumps have a description of the problem: "If your Hoover Steam Vac is leaking or water will not come out of the attachment hose, then this is the part that you probably need !!!
This part is for F5914-900 model. Hope this helps
Aug 29, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Jul 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Apr 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
88 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
