Question about Maytag PYE2300AY Electric Dryer
I have a noisy Maytag LDG 7500 gas dryer.
It starts off quite noisy, then settles out at a louder than normal rumbling noise after less than 30 seconds. the loud noise comes back when it shuts off for less thsn 30 seconds
    Sergeant:
  • 311 Answers
Thats your blower wheel.pop the hood take off the frount the blower is at the bottem.if you are able to turn it and the drum dose not turn thats your problem
Posted on Dec 31, 2008
Very Constant Noisy Fan
If this is a recent change in PC behavior, then it may be over-heating.
When was the last time you blew the dust out of the case ? This must be done 1 or 2 times a year, (more if you live in a dusty environment -- desert.)
Get a can of compressed-air, disconnect all cords, take the side off, take the tower outside, (you do NOT want to do this indoors -- trust me,) and blow it out. If there is a 'shield' on the heatsink, remove it so you can blow out between the fins there. Don't forget to blow out the Power Supply.
Tip : When the can gets cold, then the air will begin to freeze at the nozzle and it will become less effective....so STOP using it when it's cold -- you are just wasting the propellant. It is best to use TWO cans, one at a time....switching when one of them gets cold.
Apr 03, 2014 | Packard Bell Computers & Internet
Packard Bell oneTwo L5351
hmmm.. seems had a problem directly on the hardware side of your computer. my only and good recommendations to you is, first, check if your packard bell desktop has or still have a Warranty, if its on warranty, you can go to the service center to check the hardware of your PC. Second, if your computer is Out of Warranty you can check it by your self, open your CPU Drive, clean the dust inside the Hardware then check everything if all the wire's are still INTACT to each other.
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
Old Maytag LDG 7500 AAL. Where is the correct placement for the fiber and spring washer on the two rear pulleys ?
Hi there the spring washers for the two rear pulleys have been superseded for quite some time now. The current replacement kit contains two fiber washers for each pulley. However, if memory serves me right the spring washer goes on first, then the pulley, followed by the fiber washer and the circlip.
Jul 06, 2011 | Maytag SDG4606A Gas Dryer
My frigerator is making a very loud noise coming from the ice maker area. It sound like a airplaine engine getting ready to take off. Sometimes it gets louder and louder. If I turn the switch to off then...
the noise is the evap fan hitting . now either its comming off the motor shaft or its hitting ice build up caused by incomplete defrost . It's time to call the repair man . as the noise will quit and the cold will too . mm
Jul 06, 2010 | KitchenAid (KSRD22FKST) Side by Side...
I have a '96 cavalier that makes a humming noise in the gas tank within 5 seconds of starting. I have tried two fuel pumps but the noise is still there!!!
Your fuel pump is supposed to hum, when you turn the key it primes the system and it will hum. When the car is running the fuel pump is running and it will hum. If the noise is excessive then try a higher quality fuel pump, it may be less noisy. You will hear the fuel pump on a lot of vehicles tho when you are sitting at a stop light with your radio off and everything quiet in the car.
Apr 08, 2010 | 1996 Chevrolet Cavalier
Dryer makes clunking noise when it starts and stops. Also noisy during the drying cycle. It's a Maytag
May need a new blower wheel.
The wheel is mounted to the motor and if it is stripped out it will not move air past the heat element.
Have it checked before the heat element fails.
Jan 16, 2010 | LG DLE2515S Gas Dryer
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Runs louder than normal then just stops.
most common causes of a noisy dryer are bad drum support rollers, a bad idler pulley or a bad blower wheel
May 04, 2009 | Maytag MDG9206 Dryer
Maytag PYE2300AY Electric Dryer Logo
205 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
