Question about Dell (E210882) Motherboard
I put a used e210882 socket 478 motherboard into my computer. which is a emachine. when i start booting the computer ask me what file to download windows xp into. what file should i send it to.
  • c0rnymunky May 11, 2010
    What asks you what file to d/l XP into? Is it a DOS-ish look or is it a XP-ish look?
    Scholar:
  • 35 Answers
It is probably asking you to insert an XP disk, as Windows XP will need to install the new drivers for your new motherboard.  It will also give you the option to select a folder (this is what you are seeing) already on your hard drive that would contain the proper drivers for that motherboard.  Chances are this folder does not contain the proper drivers.  You will need an XP disk to install these drivers.  Boot with the XP disk in, and chances are Windows will take care of everything else.  If you do not have the XP disk you used to originally install Windows on that machine, then you can use a seperate PC to get the drivers required.  You will need to visit the website of the manufacturer (I believe emachines is your new mobo?) and download the drivers.  Then save them to disk.  When booting into your new system, make sure this new disk (you made from other pc) is in the drive, and then select that drive when it asks you for the folder you are talking about.  This will then install the proper drivers and you will be up and running shortly.  Hope this helps :)
Posted on Jan 01, 2009
Need display driver
http://download.cnet.com/mobile-intel-r-945gm/3000-2098_4-98144.html
http://download.cnet.com/intel-r-82852-82855/3000-2098_4-94913.html
if these driver packages are not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name display driver you might have to try a few times to get it right
hope this helps
Jun 18, 2012 | Intel E210882 Motherboard Socket Micro Atx...
Right i need the size or model for the cooling fan that all intelboard mode E210882
The Heatsink/Fan combo is based on the processor socket used.
After a few search hits, I have seen E210882 on Intel based motherboards, that use two different processor sockets.
The Socket 478, and the LGA 775 processor socket.
The socket for the Socket 478 has the pin holes. The Processor has the pins. (478 of them)
http://en.wikipedia.org/wiki/Socket_478
The socket for the LGA 775 processor socket has the pins. The Processor has the pin holes. (775 of them)
http://en.wikipedia.org/wiki/LGA_775
Identify which processor socket you have, buy accordingly as to the Heatsink/Fan combo.
One example of a Heatsink/Fan combo for an Socket 478 processor socket,
(Only Intel uses the Socket 478 for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=578161&CatId=795
One example of a Heatsink/Fan combo for an LGA 775 processor socket,
(Only Intel uses the LGA 775 socket for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3302824&CatId=1588
Remember to observe Anti-Static Precautions, Thoroughly clean the top of the Processor's case, and aplly fresh new thermal paste.
(A Processor is the most susceptible hardware component to Static shock)
[ Example of thermal paste,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503 ]
If you would like advice on how to properly clean the processor's case, properly apply thermal paste, and/or what Anti-Static Precautions are, post in a Comment.
Nov 07, 2010 | Intel Motherboard
Is model e210882 64 bit compatable
No, that board is 32 bit only.
Thanks Mark
Feb 05, 2010 | Intel Motherboard
What excately is the E210882 Motherboard ( this one also has the AA of D16711).This is living hell tracing down,,,
The motherboard should be:
Intel D865GVHZ (E210882) Socket 478 865GV Chipset 800MHz FSB
Nov 06, 2009 | Dell (E210882) Motherboard
E210882 is the number on the motherboard on my Emachine computer. i'm trying to disable the onboard video card with a jumpper setting so it will reconize a older but working pci 3dfx monster 3d card I put...
You can disable the onboard by visiting your bios.
On boot it will tell you to press del f8 f2 etc to enter the setup from there you can navigate around to disable the onboard and choose the lane your older pci card is in.
Oct 11, 2009 | Dell (E210882) Motherboard
Will this motherboard work?
in short, no
her cpu is a 775 socket, yours is 478 socket
her ram is ddr2, your is ddr1
would have to downgrade her parts to use your motherboard
Jun 08, 2009 | Dell Dimension 3100 PC Desktop
Sound driver of intel E210882 motherboard
Hi rukan
intel e210882 motherboard drivers can be found at
driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Apr 08, 2009 | Intel Motherboard
Ethernet Controller
Hi
E210882 is a number found on more than one Dell System Board. Dimension 8400 and 4600 come to mind. Possibly there are more. Secondly, E210882 is not a Dell Part number (DP/N or DS/N). While Dimension 8400 is a 775 socket, Dimension 4600 is a 478 socket. So they don't fall to the same family.
In any case the network controllers used on Dell System Boards are Intel and Broadcom.
To proceed, at least provide/confirm the system model. If this is not available, give the Dell Part Number.
Mile
Jul 10, 2008 | Dell (E210882) Motherboard
Dell (E210882) Motherboard Logo
670 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
