Question about Plumbing
Newport brass kitchen pulldown loose
How to tighten pulldown to escutcheon. Will not open or close unless pulldown is pressed against the escutcheon
  • 68 Answers
Is the wait on the line to draw it back and did u check under the sink to make sure ur not hung up on anything?
Posted on Feb 07, 2009
Clip will not come loose from kitchen facent moen 7100 to remove carttridge
If you didn't open the faucet to relieve the pressure, the cartridge is pushing up against the clip. Making sure that the valves under the kitchen sink are closed, and open the faucet to relieve the pressure. There is usually a hole at the end of the clip which you can stick an awl into to help removal. Good luck!
P.S. Make sure to note which side of the brass spindle has the notch on it. It should be either facing you, or it should face away. If you put it in wrong, you will reverse the hot and cold. If this happens, simply remove the handle and rotate the spindle 180 degrees to reverse it back.
Jul 01, 2017 | Moen Plumbing
I have an older model 841 bath wide base fixture that has stiffened up to a point it takes a man to open and close it. It looks very much like the current 800 fixture except it has a porcelan base. i...
Below find the diagram for your faucet....
The handles are held on by a set screw either under a cap in the center of the handle, or on the side with an allen head screw
one the handle is off, you unscrew the eustecheon cap and can get into the cartridges that most likely needs cleaned or replace.
You can contact Newport brass for parts and info below...
Contact InformationNewport Brass is committed to providing the highest level of customer satisfaction. We look forward to assisting you. Please contact us using the information below.
US Customer Care Center
Aug 23, 2011 | Newport Brass Plumbing
945 Kitchen Bridge Faucet - Swivel Spout, 9-1/2" (no Han) Brand: Newport Brass NB945-26 Series: 900 The stem moves up and down slightly when I turn on/off the water pressure. It does not leak but...
There is a good chance that if you remove the handle there will be a retainer of some sort. The retainer's job is to keep the stem/cartridge from pushing out due to water pressure. It may be in the form of a nut or a clip. Be careful removing the handle because if the retainer is completely disengaged then the stem/cartridge may shoot up. Turn the hot and cold water off at the valves located under the sink and relieve the pressure by turning the faucet on. If it's a loose nut it will spin freely. Tighten it. If it is a clip you may need to play with the stem/cartridge to align it properly before the clip will move into place..
Jul 15, 2011 | Newport Brass Plumbing
I am trying to uninstall an American Standard 4205.104 Reliant + combi faucet in my kitchen and have been unable to remove the "mounting kit". The faucet is loose. The paperwork that came with...
Hi, TYhe instructions for both models are the same. The 2 different methods of installation/uninstallation in the instructions refer to whether or not an escutcheon was used when installed. The escutcheon is the chrome piece that encircles the faucet and fits on the sink. So, if you have just a bare, chrome tube entering the sink, there is no escutcheon.
I hope this helps. Please click a vote for me if it does.
Handie Andie
Mar 27, 2011 | American Standard Reliant+ 4205.104.002...
How to insert bearing washer on moen single handle kitchen faucet
I have the exact same problem! The gray plastic washer has popped out from between the plate and the brass groove below the washer! I can't for the life of me get it back under there. Because it's sitting too high, the handle doesn't fit and the metal plate is loose.
Please help!
Apr 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Delta 473 loose connection to sick
There should be a nut holding the plate on. What is holding the u-shaped plate up?? You can't tighten the faucet from above. Seems strange the nut disappeared.
Aug 08, 2009 | Delta Model 473: Saxony Kitchen...
Repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
Plumbing Logo
53 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
