When i turn my dryer on inside it will not go around it just makes a buzzing noise.
I'm not sure if it is a 63942 but in order to get an answer i had to click on something.
remove the back panel and check the heater box fuse on your right top,also check the heating element right side bottom,make sure done of the wire is broke inside-mike
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
the belt is twisted how do i replace kenmore 80 series
