Question about RCA DRC105N DVD Player
Disk is inserted yet message says no disk inserted
  • cyberalpy Mar 11, 2009
    disk is inserted yet message" problem. it is not playing dvd but playing cd
  • RCA Master
  • 19,396 Answers
If the DVD is not reading any CD, or DVD, then it is often a lens problem.
Try first cleaning lens with a lens cleaner DVD, possibly one with cleaning solution, that can be purchased at any computer & electronics shop.
If that does not work the unit must be taken apart, to clean the lens pickup with isopropyl alcohol and soft cotton tips.
If this happens only with a single DVD , then the disk is dirty , scratched or defective, or , if it is blank the unit does not like the particular brand.
Posted on Jan 07, 2009
Getting message "Disk Boot Failure Insert system disk and press enter" using window xp platform and have MCA fee antivirus software
this happens either the boot sequence have changed or your hard drive is not recognised by the BIOS
Jan 26, 2013 | Computers & Internet
What's your problem?when i insert into compact disk the give the message please insert disk. please solved my problem..
put other working cds.if working,ur cd is damaged.if other cds are not working,ur cd drive is damaged.contact to ur service provider.
Jun 16, 2012 | Computers & Internet
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
Dell demension 3100 dvd plays any disk ok but will not burn
when you try to save or burn any data to disk, you should use burning programs just like nero or any other burning program. at the time when you click the button burn, it always ask you to insert disk such as CD/DVD +R or RW
Mar 25, 2010 | Dell Dimension 3100 PC Desktop
Dvd rw not funtioning, a message is shown repeatedly insert disk
Try using the ROLLBACK DRIVER option from the Device manager. This should fix the issue if not try updating the driver software for the DVD drive.
Jul 10, 2009 | Lenovo 3000 N200 Notebook - Intel Celeron...
Getting message:please insert a disk into disk H:
I think you will need to format your drive and this will erase all your files and fixed your problem with your disk.
Apr 04, 2009 | Kingston Technologies 512MB DataTraveler I...
Pendrive error message "please insert a disk in removable disk"
right click my computer.
click manage
selest disk management
right click to drive-H
select change path 7 name of drive
change it to any letter except lettur used for your other drives
thats it it is done.
Dec 23, 2008 | IBM Iomega ZIP 750 (22P7099) External ZIP...
My pc won't boot up and there is message to insert system disk. I insert the disk boot up to the same message.
Take out all the disks from your computer drives and start up again.
If the computer prompt for a disk or OS, probably you have a HDD problem.
To get your CD drive available to boot...you must set that option on your PC bios (boot options menu)
Oct 06, 2008 | Computers & Internet
Moser baer 4 GB pen drive is not working
i have 4gb moserbaer pen drive when i inserted it in to the Xp system it give the message "Insert disk"
plz. solve this problem.
Aug 05, 2008 | Computers & Internet
LOCKV116
hello, i have a Kingston 2GB Pendrive.I had run a program "LOCKv116.exe" on my pendrive and set password on it, but now after inserting pendrive to my pc, it is detected but when open it this message appears "please insert a disk into drive G:" If try to format it message is "There is no disk in drive G:"..If I run the program LOCKv16.exe it shows a message "please insert the device or run this utility as previledged user."
Dec 28, 2007 | Computers & Internet
RCA DRC105N DVD Player Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
