Question about Mitsubishi VS-60707 60" Rear Projection Television
Mitsubishi VS-60707 My projection tv has horizontal lines across that then scroll vertically; stated on warmup/startup then went away. Now the lines are almost constant. Could this be a lamp problem, capacitor, or both? Can this be a self repair or is it more complex?
  • Anonymous Mar 17, 2014
    TV has an rainbow image across the screen
Have same problem on 42in. Problem appears to be a short on one of the boards. If hold the cable input connection and give it a jiggle, it will usually pop in.
Posted on Aug 26, 2007
Vs-45607 was a hand me down and did not come with a remote. the picture has very fast rolling vertical lines........Help!
Typically you can open the back case and you will see two screws, one for vertical scroll and one for horizontal scroll. with a rubber head flat head you can adjust this. Please be advised this is very dangerous and has high voltage. Please get a tech to look at this, he must be familiar with this TV.
Sep 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Horizontal lines
Sounds like you need a service call to check your convergence amps. This is not a repair you should attemp on your own. More parts are probably defective than just the amps. Fuse and resistors in the amps circuit.
Dec 27, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60707 60 in. Rear Projection Television
When it gets better after warm up it can be a capacitor in the 160 Volt high voltage circuit or a cold solder joint. these 2 thinks would be my best guess on this set.
Oct 26, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Horizontal lines and screen bounce
You have some leaky filter caps - C2C52 = 10MFD 50 VOLT (off base of Q2C51 on signal board) also check C2P05 = 100 MFD 16 VOLT off pin #3 of IC2P01 and C2P08,C2P03 = 100 MFD 16 VOLT
Aug 22, 2007 | Mitsubishi VS-60707 60" Rear Projection...
My Mitsubishi VS-60707 Problem...Need Help!
There are two common problems with this set that cause the symptoms you described. Both of them are caused by capacitors: CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03. They are located on the signal PCB. Both capacitors are inexpensive and will more than likely solve your problem. Hope this helps.
Apr 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-5059 50 in. Proj. Televsion
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. This should not be an expensive job at most repair shops. Could be something as simple as cracked, cold, defective solder joints around and near the vertical output chip, could be a faulty chip and other components in and around the vertical deflection circuitry, or a faulty vertical drive signal from the jungle circuits, or worst case a faulty deflection yoke. Take your television to a shop right away for a proper and safe repair. Do not keep the television looking at the red horizontal line.... you can easily damage or burn the CRT phosphors. Good luck
May 27, 2006 | Mitsubishi VS-5059 50" Rear Projection...
Mitsubishi VS-60707 60" Rear Projection Television Logo
145 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
