Question about Admiral AAV7000A
Blk wire burned off at heating element admiral dryer ade7005ayw
I replaced terminal once whats cauing it to burn off
  • Anonymous Apr 26, 2009
    Same problem here, replaced the wire and terminal also put in a new hi-limit therostat and a thermal fuse but it burnt off again.
    Sergeant:
  • 311 Answers
Lets see hear.a loose connection draws maximum ampreage so important that any connections are clean and tight then another thing could be vent .if its is restricted at all your heater will run hotter putting stress on those connections
Posted on Dec 31, 2008
Converting 4 prong admiral ADE7005AYW to a 3 prong
Hi pete
Go to the following webpage and you will find the answers you are looking for.
Bud
Apr 24, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Where is the heating element located in an admiral model no. ADE7005AYW
Take a look at this video to show you how to open the cabinet. The element is on the lower right side.
Nov 05, 2012 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Can't open Admiral ADE7005AYW
Try sliding a thin putty knife rearward at each front corner of the top while lifting upward slightly. Shine a light into the joint and look for metal joining the two halves. Once the top is loose, look for screws in the inside front edges and lift up on the front panel to release. Make sure to pull the power plug while working in there.
Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
Not heating
you have a dead short somewhere or someone monkeyed around the dryer to repair it
Jun 18, 2009 | Amana DLE330RAW Electric Dryer
The black wire burnt off on the line going into the heating elem
No, you do not need to remove the drum. But you will need to remove the cover from the blower assembly. Using a volt meter, check the elements continuity to determine if it is bad or good.
Apr 16, 2009 | Whirlpool LER5636P Electric Dryer
Heating element
Might I suggest this site if you are a do it your self.
http://www.appliancerepair.net/dryer.htm
You have to raise the top take off the front and the tub should come out. Wala the heating element. Hope this helped, if not let us know.
Mar 16, 2009 | Dryers
ONE OFTHE CONTACTS KEEPS BURNING AT ELEMENT
You will have to replace the heat element, because the male terminal is burnt, which causes too much heat at the connection, and causes the wire to burn. If you can clean the terminal to where its shiny it may work otherwise replace the element
Dec 18, 2008 | Roper REX4634KQ Electric Dryer
Admiral Dryer (Model # ADE7005AYW) wire connector burning causing no heat
I had the same problem with my dryer. Fixed it with high temp wire (875 F) and end connectors rated for the same temperature. Make good connections between the wire and the connectors because if they are poor they will heat up as well. Sometimes the thermostat will cause this problem as well or an older heating element that is going bad.
Nov 05, 2008 | Whirlpool LER5636P Electric Dryer
Admiral Dryer will not heat
Bad connection
this wiil cause this make sure to use a Hi Heat connector abnd the connections are tight
Apr 27, 2008 | Whirlpool LER5636P Electric Dryer
Heating element
Disconnect the power.
Slide the Dryer away from the wall.
Pop up the top
You should see the heater in the back.
Remove the wires connections, and move them to the side
Remove the retianing screws
Pull the heater out.
Put the new heater in and reverse the procedure.
Oct 29, 2007 | Whirlpool LER5636P Electric Dryer
Admiral AAV7000A Logo
292 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
