Question about SmartParts SPX8 Digital Picture Frame
How can i get the memory card out of the card slot?
It is too far inside slot.
Push the card in then let it "pop out" to where you can pull it the rest of the way out.
Posted on Jan 29, 2009
  • 33 Answers
You would need a type of surgical tweezers. Thin but strong. You best bet would be to bring it to a local camera shop to try.
Posted on Dec 31, 2008
I receive a Card Error message when I try to take a picture. I have replaced the batteries and have a new sim card.
hi,
either your memory card or memory card slot have snags, if you checked with another memory card then the fault should be in memory slot, just look inside the memory card slot with a flash lite if the contacts is bent, if it is bend or shot circuited, open the camera and make it straight with a tweezer tool. if any dirt or dust inside, try to clean it with an air blower then spray some contact cleaner in.
Feb 18, 2016 | Cameras
I have a SanDisk 6-in-1 PC Card Adapter. I asked my son to put in a Memory Stick Duo into the Reader but he pout into the wrong slot. I cant get the memory card out.
You might try some thin tweezers or poke a pin into it, but not too far as you don't want to damage the electronics inside the card.
If these are not an option and that card is really full of photos you do not want lost etc, you pay have to break down and take apart the sandisk card reader to get it out.
Chris
Aug 18, 2011 | Computers & Internet
How to insert memory card in the iphone 4?
Well, as far as I know, there's no memory card slot on Iphone4. Because the memory card of iphone4 is actually built in.
But other than iphone, you can find memory card slots.
Aug 18, 2011 | Cell Phones
What are the slots on the front panel used for?
Those are card reader slots.
Various types of memory cards can be used.
A memory card, (Or can be stated as Flash Memory Card), takes the place of the old Floppy Disks, for one.
It is digital. There is no disk inside, just hardware electronic components.
Due to the size of trying to explain every type of memory card that is available, and the memory card itself, I would like to give you this link,
http://en.wikipedia.org/wiki/Memory_card
Here it explains the basic format of a memory card.
You can click on the titles of the memory card/s, (in blue), to get a deeper explanation, of that particular memory card.
The specifications for your eMachines ET1810 Desktop PC, state that you have the following card reader slots for,
1.Compact Flash (Type I and II)
2.CF Microdrive
3.MultiMedia Card (MMC)
4.MMCmobile
5.MMCmicro
6.Reduced-Size MultiMedia Card (RS-MMC)
7.Secure Digital Card (SD)
8.miniSD Card
9.xD-Picture Card
10.Memory Stick
11.Memory Stick PRO
12.Memory Stick PRO Duo
13.Memory Stick Micro (M2)
Look above each slot for an abbreviation.
For example on my computer,
I have one card reader slot that is approximately 1 inch wide.
It looks like a T that is stretched out.
It has SD/MMC/SM/MS/MS-PRO, above it.
This means that the card reader slot will support, (Use),
[In order as printed above],
1.SD Card - Secure Digital Card
2.MultiMedia Card.
3.Smart Media card
4.Memory Stick
5.Memory Stick Pro
I have one more card reader slot. It has CF-Microdrive above it. A wider slot than the above, and looks like a upside down stretched out T.
This means of course that it uses, (Supports), a Compact Flash Microdrive card
I've tried to explain the various card reader slots, on your computer's front panel, without being too technical, or being offensive in nature.
If you want, I can explain as technical as you wish, or simplify my solution more.
This is the Specifications page for your eMachines ET1810,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810sp2.shtml
Scroll down, and look to the right of the heading - Card Reader.
These are the cards your computer supports, (Uses)
Looking at the main support page for your eMachines, it looks as though you have four card reader slots.
Three grouped together on the left side, and two in the middle.
The two slots to the far right are USB ports, with probably a headphone jack port, and a microphone port to the right of them.
This page gives a little more detail, as to what your card reader slots support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810fv.shtml
Dec 24, 2009 | eMachines ET1810-01 PC Desktop
Message "card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
Have put in a memory card, But camera keeps displaying memory card full
Try reformatting the card. Use your camera to do it, not a computer.
Dec 14, 2008 | Cameras
I have problem with my memory stick in w850
It should be a problem with your memory card slot in your phone. It could solved by dusting the inside of your memory card slot.
After trying this, please reply whether it worked.
Thank You
Nov 15, 2008 | Sony Ericsson W850i Cellular Phone
My vivitarN1659 will not reconize a1gb memory card and either states that the memory is full or that the memory is locked
There should be a tiny lever on the side of the memory card. Unlock the card by pushing the lever up. If it still says memory card is full, take out the battery and push the memory card further into the slot. It should not move while it is in the slot. If it "floats" when you close the battery door, it is not down far enough into the slot. Return the battery and close the door.
Oct 05, 2008 | Cameras
PS2 memory card has been removed or replaced????
WELL THIS AN IDEA FROM ME. THERE MUST BE SOMTHING WRONG WITH HE SLOT ARE THE MEMORY CARD.
!. FIRST I WOULD CHECK INSIDE THE SLOT IF IT HAS ANY DUSK , IF IT DOES DO NOT BLOW IN IT, JUST USE A PIECE OF PARER A TRY TO WIPE IT OUT.
2. SECOND I WOULD CHECK THE MEMOERY CARD IF ANY OF THE PIECES THAT GO INSIDE SLOT ARE MISSING, IF SO THEN IT WON'T WORK ANYMORE.
3. THEN I WOULD INSERT THE MEMOERY CARD , AND PUSH IT A LITTLE HARDER INSIDE, mAY BE ITS NOT FULLY INSIDE.
Hope it works for you.
Jan 01, 2008 | Sony PlayStation 2 (PS2) Console
SmartParts SPX8 Digital Picture Frame Logo
41 people viewed this question
Top SmartParts Photography Experts
Joseph Hoffmann
Tony
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
