Question about Gateway T-1631 Notebook
Shopping how would you rate the Gateway® T-1631 14.1" Laptop
Laptop capacitor
Hi Melissa,
The best i could find was on ebay.
Here's the link for the Fan
http://www.ebay.com/itm/NEW-Gateway-NV53A53U-NV53A63U-NV53A51U-NV53A50U-CPU-Cooling-Heatsink-Fan-7784-/281088859805?pt=LH_DefaultDomain_0&hash=item4172339e9d
And without telling me the type, size and rating of the Capacitor i think the best place you could find it is at Radio Shack or another store like it.
If you feel comfortable removing and replacing the entire Motherboard, here is a link on ebay for a replacement Motherboard.
http://www.ebay.com/itm/Gateway-NV53A38U-NV53A46U-NV53A47U-NV53A48U-Motherboard-MB-BL002-001-7595-/281012076283?pt=Motherboards&hash=item416d9ffefb
Hope this helps!
Thanks and please rate;)
Gary
Aug 27, 2013 | Gateway nv Computers & Internet
I need to purchase a new charger for my Gateway CX2724 laptop. Will any charger for a Gateway laptop do, or do I need to look for one for my model specifically?
there are different voltage outputs and amperage ratings on different chargers. as long as the plug fits, and the numbers are the same, you'll be fine. I would try to get a charger meant for your unit though.
Mar 27, 2011 | Gateway CX2724 Laptop Charger...
I need the size or model number for a replacement charger for the gateway solo 9550.
Compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
Aug 30, 2010 | Gateway Solo 9550 Notebook
I can not find the power button for off/on on the gateway nv53 laptop
The power button on the Gateway NV5378u laptop is in the hinge on the right side.
Jun 06, 2010 | Gateway NV5387u Notebook
How to replace gateway 3040 keyboard, need to know method to open the laptop to install a replacement keyboard
Visit this site and follow the instructions carefully.
http://www.ehow.com/how_4885524_remove-keyboard-gateway-laptop.html
Please rate me thank you
Apr 10, 2010 | Gateway 3040GZ PC Notebook
My Gateway laptop use AC cord with the output 19v = 3.42A. can I use the AC cord with the output 19v = 3.95A?
Yes you can use one that has an higher current rating. The system will only use what it needs. If you try to use one with an lower current rating the power supply would fail. Just check to make sure the pin out is the same..ie postive tip or negtive tip.
Feb 23, 2010 | Gateway HQRP Replacement Laptop AC Adapter...
41 gateway laptop drivers
i am providing you link to the manufacturers website that will help you to download all the required drivers
DOWNLOAD LINK
thanks and regards
kindly rate this solution
Oct 28, 2009 | Computers & Internet
GATEWAY LAPTOP DOES NOT TURN ON
What was the Watts rating on the wrong power supply? Compare it with the watts on the correct adapter.You may have fried your laptop. I would have a tech check it out before you buy a new one. There are many companies available offering a free diagnosis in Fix Ya's repair directory.
Aug 02, 2009 | Gateway M-1628 Notebook
Driver problem wiht ml3108b gateway laptop
Hi
Heres the gateway utility to automatically find and install drivers. Please rate if you find this helpful
http://support.gateway.com/support/drivers/getFile.asp?id=19318
Jan 05, 2009 | E-Machines eMachines Refurbished EMA...
Gateway T-1631 Notebook Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
