Question about Kyocera Mita FS-1020D Laser Printer
My Kyocera FS1020D won't print. The light says i need new toner - but the cartridge is relatively new. And you can hear the toner inside the cartridge when you shake it. I've tried switching computer and printer off and rebooting - but no luck. Can you advise me?
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
I need setup for kyocera fs1020d can anyone provide a link?
http://driverscollection.com/?H=FS-1020D&By=Kyocera
May 27, 2014 | Office Equipment & Supplies
Kyocera fs1020d only prints 1/2 page?
needs realinded,remember the first set up,it printed a page,look it up online and run the start up series on it again,if not,you have a printer or roller bar stuck.
May 25, 2014 | Kyocera Mita FS-1020D Laser Printer
Kyocera EP470DN - Has Toner - Won't Print
MHHH, it seems as if its empty but it might be that it has humidified. Take out the toner and shake it side ways without compassion, then you slow down and shake it gently a couple of times then install it at the drum. You can also verify if this is true if you take out the toner and watch the roller and see if its loaded with toner. If it looks shinny with almost no toner it what I just exposed. Luck
May 10, 2013 | Kyocera Mita EP-470DN Toner Black EPT-470
We replaced the toner cartridge and the waste receptical and the little red light "Add Toner:" is still on and the machine won't copy. We have removed the cartridge and did the dance...
If it is a Kyocera toner than that is the problem. The key to turn the toner is different for the Kyocera toner cart. It will fit and appear to work but won't. Also turn the unit off and unplug for 15 sec. will reset and perform boot up procedures might help.
Jul 07, 2011 | Copystar CS-1810 Copier
Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Jan 24, 2010 | Kyocera FS-C5015N Laser Printer
Error message - "chassis locked"
check the toner on the left had side is a locking mechanism... make sure toner is in correctly and that switch is locked...
Mar 23, 2009 | Kyocera Mita FS-1020D Laser Printer
Kyocera FS 1010 printer. Not printing even with new cartridge
may be moisture.just switch the dehumidifier on for some tine.
Jan 18, 2009 | Kyocera Mita FS-1020D Laser Printer
How to clean the printer inside
You can use an aspirator to clean the printer inside, and if you have a little experience you can clean the blade inside the cartridge with isopropylic alcohol, and the drum too. How many times was the cartridge refilled?
Oct 14, 2008 | Kyocera KM-1505 Copier
Kyocera Mita FS-1020D Laser Printer Logo
327 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
