Question about Technics SL-PD8 5-Disc CD Changer
Technics SL PD8 laser replacement
How do I separate the servo PCB from the laser assembly. Do I have to desolder the motor connections?
  • 3 Answers
The answer is yes you do. The replacement laser pickup assembly has 2 motors already fixed to it so the pegs in the suspension have to be removed (2 off) and it is best to prise open the split in the receptacle to facilitate this without damage.Then 3 screws on the pcb need unscrewing and after the solder has been removed on the motors the boards will come apart.
Posted on Jan 08, 2009
Cd tray closes quickly without pressing switch on Technics SL-pd688
There is a small switch under the tray that stops the motor at the end of it's travel, also one when the tray goes back in.
These can have wires broke off or can be stuck or open circuit
Jun 19, 2014 | Technics SL-PD8 5-Disc CD Changer
Instruction manal for technics CD PLAYER SLPD8
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Thanks for using FixYa
Sep 17, 2010 | Technics SL-PD8 5-Disc CD Changer
Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
Nov 27, 2009 | Audio Players & Recorders
SL-PD8 cd tray is opening and closing, nonstop.
I called panasonic and they told me to do a hard reset on the system it seems to have worked on mine. Hold the power button continually while you unplug and replug the unit.
Jul 26, 2009 | Technics SL-PD8 5-Disc CD Changer
FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
May 08, 2009 | Technics SC-DV290 System
When Making A CD To Play On My technics SL-PD8 It
If thhis happens quite often , and does not depend on the media, then it is usually a dirty lens problem. The lens is dirty or scratched and sometimes cannot read CD TOC (table of content).
If this happens only on reocrded CDs , try changing the media used. For example if you used +R, try with -R.
If this happens on all media, then try cleaning the lens with a lens cleaner CD or blowing some canned air on the lens.
See: CD and DVD Lens Cleaner...
May 02, 2009 | Technics SL-PD8 5-Disc CD Changer
Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Oct 09, 2008 | Technics SL-1210 Turntable
Need Manual for Technics SL-PD827
Go to http;//audio.manualsonline.com
Jun 24, 2008 | Technics SL-PD8 5-Disc CD Changer
Distorted sound when playing CD
have you tried cleaning the cd lens ?insert a lens cleaning cd , follow the voice instructions and your cd player will be as good as new.HAPPY LISTENING.
May 30, 2008 | Technics SL-PD687 5-Disc CD Changer
Technics sl pd-827, how to elect single cd?
This is straightforward. You have to ensure that the disk is stopped by pressing the square symbolled button then press disk skip once or twice and open the tray. Presto (if it is working correctly)
Nov 18, 2007 | Technics SL-PD8 5-Disc CD Changer
Technics SL-PD8 5-Disc CD Changer Logo
668 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
