Question about Aiwa FR-CD1500 Clock Radio
Display does not show complete numbers and radio plays without the radio being turned on
It has worked fine until a few days ago. You can now hear the radio playing softly even when the radio switch is not turned to on. The second problem is that the display where the time shows up shows a random pattern and does not display any complete numbers. It seems like it is trying to display the numbers but parts of them are missing. Any suggestions on what could be causing this? Both problems started at the same time.
0 characters
1 Points
I can't get my 4th Gen. IPOD Nano to play on my Brookstone iDesign Cube Clock Radio.
Turn the device on
Connecting your iPod/iPhone
  1. Insert piece 17 for iPod nano (4th generation)
  2. Press and hold the iPod button until the display shows the iPod icon and the "Auto"
  3. icon.
  4. Press the iPod button again to activate Auto Play (AUTO is circled)
  5. Choose song on ipod and hit play on ipod
I hope this helps :)
Dec 30, 2010 | Brookstone (467522) Clock Radio
Our Ferguson FRG-CR100D DAB Alarm Clock Radio has lost its digital display - it just shows 16 illuminated blank oblongs in the display panel. It doesn't respond to pressing any buttons, e.g. DAB/Clock,...
I experienced a similar problem some time ago. I thought I was responsible for the problem because I run the radio of a dual voltage shaver socket and accidentally switched the socket output to 110v. From that point on the radio did excactly what you described. I perservered in trying to find out why but to no avail so I abandoned it. Some months later out of curiosity I plugged it, switched it on and it worked perfectly.
Try leaving it unplugged for a few days (which by this time will have already passed). It may just recover like mine did.
Nov 16, 2010 | Clock Radios
After a few months, the CD player stopped working. It doesn't spin, and it shows "no" in the clock display
Each CD Player has a potentiometer to adjust the laser assembly alignment. The T609t CD player has a tiny pot of 2000 Ohms (2K) about 1/8 x 1/8 of an inch on a tiny printed circuit board right under the laser assembly. I tried adjusting its value with no success. The wiper was not making contact with the carbon layer below it. I removed it and soldered in 2 wires of 6 inches to work out of the box. I attached at the end of the 2 wires a small printed circuit board of 1/2 x1/2 inch to solder a new pot of 1000 Ohms in series with 50 Ohms resistor. I started increasing the pot value until about 700 Ohms and immediately the Player showed 01 on the display and started to play IL DIVO songs. Obviously after each new setting of the pot I had to repeat the same routine: Power off, power on, hit Play, see No CD message on the display until I found the right initial value on the pot. I still had to tweek it up toward 750 Ohms because it was skipping a bit of song number 8. It is working fine now.
I taped my mod, tucked it in the box and closed the whole thing until the next time it will go out of alignment.
The pot I am using is bigger (3/8x3/8x1/4) it takes 44 turns of 180 deg to sweep it from 0 to 1000 Ohms. The old pot is swept from 0 to 2000 Ohms in one turn of 120 deg. The 50 Ohms resistor was for safety in case I hit 0 Ohms on the pot. I kept it in the mod in case I want to hook a scope.
Jan 18, 2010 | Timex T609T Clock Radio
Emerson Research Clock w/Projection Display Not Working
You will need to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio and remove the internal battery. Let the Clock/Radio set for at least 1 hour and then put the battery back in and plug in the Clock/Radio. The functions should return to normal. If not, replace the battery (CR2430) and leave the Clock/Radio unplug for a period of hours. Then put in the new battery and and plug in the Clock/Radio to see if the functions have returned to normal. If not you may have a more serious problem with the microprocessor. You can call the Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problem.
Mar 25, 2009 | Emerson Smartset Clock Radio
Spilled iced tea in clock radio/CD player
Sounds like there's still a real mess inside and it's either shorting out circuits or insulating the button contacts with the sugary residues. Best bet is take it to a repair shop since it will have to be opened up, fully dried and cleaned. You can try drying it out yourself if you're confident opening up stuff or just let it sit by a warm air vent a few days. What kind of functions or buttons are not working? Can it play audio/ set the time/ change from AM to FM....?
Feb 12, 2009 | Sharper Image SI785 Clock Radio
Volume won't go past 30
Turn on. Set volume to 00. Press & hold the volume knob for about 10 sec., until you hear a beep. Then turn volume up to the maximum that you would ever want, and then press the volume button again. It is now set.
Feb 02, 2009 | Boston Acoustics Horizon Solo Clock Radio
Emerson Jumbo Display CKS2237 clock radio
Sorry it took so long to get back to you with a answer to your question. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Oct 05, 2008 | Emerson Smartset Clock Radio
Projection display
I had the some problem a few days ago when we had a power outage during the night. Try unplugging it, leave it unplugged for about 10-20 seconds, and replug it back in. Reset your time on the clock and it should work then.
Nov 08, 2007 | Homedics Sound Spa Premier SS-5000 Clock...
Radio turns on and off by itself
I think It might be the anntenna.
May 23, 2007 | Emerson CKS3029 Clock Radio
Aiwa FR-CD1500 Clock Radio Logo
22 people viewed this question
Top Aiwa Clock Radios Experts
Gyula Lacz
Are you an Aiwa Clock Radio Expert? Answer questions, earn points and help others
