The rim specs need to match. These are the measurements for the rim NOT the tyre. The bolt hole pattern matches but the problem you will have is the OFFSET. This is how far the wheel sticks out of the wheel arch. Too low a setting and the tyres will rub inside the wheel arch. Too high and the wheels will stick too far out of the wheel arch. Each giving its own mechanical problems.
Fig. Accessory drive belt routing-2.7L engine Chrysler Cirrus & Sebring Convertible; Dodge Stratus; Plymouth Breeze
Fig. Accessory drive belt routing-Chrysler 2.7L engine
2.7L Engine A/C & Alternator Belt
Raise and safely support the vehicle.
Remove the right front wheel and belt splash shield.
Loosen tensioner locking bolt and pivot bolt.
Rotate tensioner clockwise to allow enough slack to remove belt
To install:
Install the air conditioning compressor/alternator belt on pulleys, tensioner in slack position, slip belt over idler last.
Adjust drive belt tension.
Install the belt splash shield and right front wheel.
Lower vehicle.
Fig. Installing A/C & alternator belt-2.7L engine
Before servicing the vehicle, refer to the Precautions Section.
Loosen the tensioner locking bolt and pivot bolt.
Rotate tensioner clockwise to allow enough slack to remove the belt
To install:
With the tensioner in a slack position, install the Air
Conditioning (A/C) compressor/alternator belt on the pulleys. Slip the
belt over the idler last.
Adjust the drive belt tension.
Install the belt splash shield and right front wheel. Tighten the wheel lug nuts to 100 ft. lbs. (136 Nm).
Lower the vehicle.
Power Steering Belt
Remove the air conditioning compressor/alternator belt.
Loosen belt adjusting bolt. It is not necessary to loosen the
pivot bolt on the power steering pump. There is a bushing incorporated
into the power steering pump/bracket that allows it to pivot.
Remove the power steering belt.
To install:
Install the power steering belt on pulleys.
Install the air conditioning compressor/alternator belt.
The most likely location for the pump and filter will be mounted on the body behind the rear wheel arch liner on the right hand side of the car, (driver's point of view).
It's fun. You go through the right front wheel well.
Before starting, consider a pressure wash of the areas in question. You'll need an easily movable light source too.
Procedure for pulling the alternator
1, Disconnect Negative battery cable. 2. Remove the serpentine belt. 3, Jack up the right front end.
!!! Use additional jack stands, engage e-brake and make sure the wheels
are chocked. You do not want the car to fall while your working on,
under or inside it !!!! 4. Remove the right front tire 5. Remove
the wheel well splash shield. The splash shield is held on by a dozen
or so anchors. Use a small flathead to pop the centers out. They should
slide out. You'll get it. Remove the shield. 6. Remove the field and Bat+ wires. 7. Remove the two bolts. The alternator is now loose. 8. Remove the alternator through the wheel well. Don't get frustrated. It really can be done.
