Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Side by side refrigerator- will not freeze or get cold
I have an admiral side by side refrigerator approximately 10 years old. The freezer will not freeze and the other side will not get cold. Even after the temperature dial has been move to the max., the frig still did not get freeze or get cold.
    Genius:
  • 1,036 Answers
The main question is does the compressor at the back work or not. If it is running (constantly), then I'm afraid you need a replacement which is a service engineer job. If it never runs, then it is almost certainly the control system at fault. This will probably be a circuit board replacement to fix.
Posted on Dec 31, 2008
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Why does freezer get cold but not refrigerator side?
Check the freezer temp (available in most grocery and home improvement stores). The temp should be between 0-10 degrees F (not just barely below freezing).
You can also try to find a solution on www.repairclinic.com or click here.
Aug 13, 2009 | KitchenAid KSRG25FKSS Side by Side...
I have an admiral refrigarator but it doesnt get cold both sides
Sounds like a bad freezer fan motor .(in the freezer section)
Aug 02, 2009 | Admiral 26 cu. ft. Side-By-Side...
Fridge not cooling on either side of side by side. Approximately 10 years old, its an Admiral.
is there frost in the back of the freezer? fans running? tell me anything you can tell me about the ref.... model number would help
Jun 23, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral side by side refrigerator won't stay cold.
change the defrost thermostart or check door(ajar) or damper control
Mar 26, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral SAC224 fridge freezer: fridge intermittently freezes up
To Whiteorchid,
Found a fix for my issue ... hopefully it'll help you.
Up at the topleft rearmost corner of the fridge remove panel to reveal spring attached slots where cold is supplied from freezer. The spring attached had came off one end as there isn't a "slot" for the spring to hold in place (design fault?).Reattached the spring and taped on .... and hey presto fridge now working perfectly again. Hope this helps.
Sep 01, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator, s/side, too cold, etc
unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Apr 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
183 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
