Question about Maytag Performa PAV2200
Buzzing under refrigerator and freezer warm
I have a maytag performa 4.5 years old and i hear a buzzing under the front right and now my freezer won't stay cold...starting to defrost
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls postback the exact model number.
Offhand, without an exact model number to work with, possibilities that the buzzer like sound could be produced by:
  • a real buzzer indicating a malfunction;
  • the compressor trying to start but could not.
Good luck and Thank you for using FixYa.
Posted on Dec 31, 2008
    Genius:
  • 1,239 Answers
Hi
My guess is that you have a problem with one of the following:
Start relay...this gives a quick shot to the compressor to start the cycle...if it doesn't shut it will go to overload. The capacitor in the start circuit which assists the start relay or the compressor itself. Best bet: get a service guy i
  • ABHISHEK.C
    ABHISHEK.C Dec 31, 2008
    or  This has the ADC board in the control area, so your best way to start checking this defrost system is to check the defrost heater and the termination thermostat in the freezer, if they check good then you will know the ADC board is defective.  Assuming you have checked behind the back wall of the freezer after you open the freezewr door, to see if it is clogged with ice.  If the heater or bi-metal are bad, replace them, and be sure to defrost all of the ice on the coils with your hair dryer.  If this is not clogged with ice, you have other problems which will be addressed once we hear about what you have found behind the freezer panel. Look at the frost pattern also, if it is not all frosted up you have other problems.
    Genius:
  • 3,422 Answers
HI,
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
Thecompressor is a football-sized case with no apparent moving parts. It'son the outside of the refrigerator at the back near the bottom. If itis humming or making a continuous noise and your refrigerator is stillnot cooling, there may be a more serious problem with one or more ofseveral different components, we recommend contacting a qualifiedappliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor Foran overall understanding of how refrigerators should work, read aboutrefrigerators in the How Things Work section of our website. Arefrigerator or freezer that is cooling, but cooling poorly, may have aproblem in one of several areas:
Evaporator coils
Condenser
Poorcooling is often the result of a heavy frost build-up on the evaporatorcoils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poorcooling is often the result of a heavy frost build-up on the evaporatorcoils. You can't see these coils without removing a panel on the insideof your freezer. A sure sign that there is a build-up is the presenceof any frost or ice build-up on the inside walls, floor, or ceiling ofthe freezer. Such a frost build-up usually indicates a problem in theself-defrosting system or damaged door gaskets.
The refrigeratoris supposed to self-defrost approximately four times in every 24 hourperiod. If one of the components in the self-defrosting system fails,the refrigerator continues to try to cool. Eventually, though, so muchfrost builds up on the evaporator coils that the circulating fan can'tdraw air over the coils. There may still be a small amount of coolingbecause the coils are icy, but with no air flow over the coils, coolingin the refrigerator compartment is quite limited.
Here's aninexpensive, though inconvenient, way to determine if the problem iswith the self-defrosting system. Remove all of the perishable food fromthe refrigerator and freezer, turn the thermostat in the refrigeratorto Off, and leave the doors open for 24 to 48 hours. (Be sure to haveseveral towels ready in case the melting frost and ice causes the drippan to overflow). This allows the refrigerator to defrost "manually."When the frost and ice build-up has completely melted away, turn thethermostat back to a normal setting. If the refrigerator then coolsproperly, it indicates a problem with one of three components in theself-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
Ifit still does not cool properly, there may be a problem with therefrigerant level or the compressor. You may need to consult with aqualified appliance repair technician to further diagnose the problem
Condenser Self-defrostingrefrigerators all have a set of coils and a cooling fan, usually underthe refrigerator, that need to be cleaned regularly. If these coils getcoated with dust, dirt or lint, the refrigerator may not cool properly.The coils may appear to be a thin, black, wide radiator-like devicebehind the lower kick-panel. To clean them, disconnect the refrigeratorfrom the power source, use a refrigerator condenser brush (see theAppliance Accessories section) and your vacuum cleaner to clean thecoils of any lint, pet hair, etc. You may not be able to get to all ofthe condenser from the front, it may be necessary to clean theremainder of the condenser from the rear of the refrigerator.
My 20 year old Maytag fridge has stopped cooling properly. It will cool the freezer to about -4 then warm to about +4 and continue to do this. What might the problem be? i
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Maytag Refrigerators
I have a side by side maytag fridge model number MSD2655HES it is about 6 years old. It seems to be cooling fine but makes an intermittent buzzing noise followed by a click what could this be?
heatman101
Aug 29, 2011 | Maytag MSD2655HES Side by Side...
Maytag Performa - PTB1953DR - FRIDGE IS NOT STAYING COLD, WE HAVE IT UP THE ENTIRE WAY AND IT IS COOL BUT NOT COLD. FREEZER IS STILL FREEZING BUT NOT WHAT IT SHOULD BE, ICE CREAM IS FROZEN BUT NOT HARD.
heatman101
Aug 08, 2011 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
Clicking sound and freezer not working in bottom mount Maytag fridge 7 years old
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 14, 2011 | Maytag MBB2256GES Bottom Freezer...
I have a Maytag side by side F/F. The freezer although on is not working and have had to throw all the food away. The fridge is also very warm and water has been leaking at the bottom. Not too sure...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 01, 2010 | Maytag MSD2656G Side by Side Refrigerator
Maytag performa model ptb1553gr not coolingand had a burnt smellbefore defrosting itself
heatman101
Oct 28, 2010 | Maytag Refrigerators
My Maytag French Door refrigerator MCFC2061HES recently started making a buzzing noise. The refrigerator is 5 years old. What is the problems. Please tell me it is not the compressor.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 16, 2010 | Maytag MFC2061HES Stainless Steel French...
Maytag Refrigerator - freezer not working
heatman101
Feb 27, 2010 | Maytag Performa PAV2200
Maytag french door fridge crapped out....again
buzzing sound comes from freezer fan or ice maker fan. They are located behind the freezer rear wall. These freezer fan cools the freezer and the refrigerator. The ice maker fan supply air to ice maker.
Jul 22, 2009 | Maytag MFD2560HES Bottom Freezer French...
Buzzing under and freezer stopped cooling
wheres that buzzing coming from.is it your ice shute door opening and closing if so you may need a new board
Dec 31, 2008 | Maytag Performa PAV2200
Washing Machines Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
