Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Dots on Pansonic LCD Screen popping up
Panasonic 61" TV LCD with color dots popping up all over I'm up to eight. I heard yall had the solution.
  • touchmizan Feb 24, 2009
    a little bright dot on my BenQ LCD E2200HD monitor screen. can any one solve this problem.
  • 927 Answers
Howdy,
The problem is with the EEPROM in the TV that needs to be reprogrammed. But you need to have the proper Correction Tool (LSUQ0100).
I don't think it's available to the public. Call a Service Company, but make sure they have the “Correction Tool”.
Thanks for using FIXYA, thanks big IRISH.
Posted on Jan 02, 2010
AFTER REPLACING THE LAMP, I HAD TO PUT THE COVER ON AND NOW THE SCREEN HAS TINY BLUE DOTS AND THE POWER LIGHT STAYS GREEN. THE LAMP LIGH IS NOW ON AND RED
The blue dots are due to a failing optic block. The lamp is only making them show up more obviously. The TV is probably failing as the blue dots will get larger and eventually take over the screen.
Sep 12, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
Yellow spots and white dots on the TV screen.
Light Engine/optical unit block.
Encompass Parts Distribution 1-800-638-3328
UED 1-800-648-6657
Sep 28, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Blue dots on screen. what is it and can it be fixed? a new bulb was recently installed.
Yes,it is repairable.Blue dots on screen is sign of LCD failure at optical block assembly. There are three LCD on the optical assembly RED,GREEN and BLUE. Blue LCD failure causes blue dots on screen. Repair should be done by replacing blue LCD. Note! LCD replacement needs Extra care and precise tools such as oscilloscope and color pattern generator , for the color alignment after replacing LCD. But if you can afford, replacing the optical block is better,
Sep 26, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic pt-52lcx65-k color problem
I have the same problem. i called panasonic they said it was a on
going problem and they would send out a repair tech no charge to
fix problem.give them a call 1-888-843-9788
Jan 04, 2010 | Panasonic PT-52LCX65 44" HDTV
Three inch red dot appears on my Panasonic tv screen. It is an LCD. Can it be fixed? What do you think it is? The dot shows up mostly on the light scenes.
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and inspecting the lamp itself and the lens that it shine onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly.
Sep 20, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
I have a SONY LCD TV model KDF 50WE655 w/ Blue Dots on screen :(
The blue dots are cause by a defective optical light engine. This parts is quite expensive.
Read the info from this link for more info.
Jul 02, 2009 | Televison & Video
My panasonic pt-61lcx has green dots on the screen)
sorry but it's the bulb.....hince why there is a class action lawsuit against them......
Feb 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Tv problems need help
I had same problem
Apr 16, 2008 | Televison & Video
GREEN DOTS ON SCREEN PANASONIC PROJECTION HDTV 1080I
Ah, big no-no.
This is the result of the coloring being pulled to the front of the screen.
This is caused by magnets. Anything magnetic will cause this, even a small one.
Hopefully you have warrenty, this is pretty expensive to replace.
Jan 02, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
214 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
