Question about Maytag Performa PAV2200
Buzzing under and freezer stopped cooling
I have a maytag performa side by side w/ water/ice dispenser. ther is a buzzing sound every 30 seconds and now my freezer seems to be defrosting or warming up. the unit is about 4.5 years old. any advice would be appreciated.thanks
  • Maytag Master
  • 3,463 Answers
The buzzing noise u can hear is the motor compressor tying to start up. It is drawing too much current due to probable seizure of motor or faulty start relay, this is causing the overload protector to operate, and what u can hear is the motor trying to start. the overload then resets and the motor trys to start again.
Unfortunately this is not a D.I.Y job, you need to call a specialist.
Plz rate this solution.
Thanks.
Posted on Dec 31, 2008
    Sergeant:
  • 311 Answers
Wheres that buzzing coming from.is it your ice shute door opening and closing if so you may need a new board
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
My maytag msd2657heb i could hear it running but the fridge and freezer not cold at all
It can be faulty compressor or issue with defrost.
These will help.
Thanks,.
Seems to be cooling fine but makes a buzzing sound for 7 seconds then stop.
The 7 second buzz would be from the water valve trying to fill the ice maker that is in the freezer.
My guess is that your refrigerator is not connected to a water supply. You can stop the buzz by opening the freezer drawer and turning off the ice maker, it will have either an on/off switch or an arm on the right side that lifts up and locks in place, that will stop the buzz
Apr 18, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
My maytag refrigerator started making a buzzing noise every time it goes on. it lasts about 5 seconds then clicks off. any idea what it is?
I have the same problem. It is ice buildup around the evaporator fan that begins as a buzzing (the fan blades hitting the advancing "glacier"), which ultimately stops the fan and then the freezer/fridge stop cooling. Just pull the lower sheet metal from the inside rear of the freezer (need to remove some screws from upper sheet also) and chip the ice away. I've got a question in to Maytag now to see how to prevent this from recurring. I've had to take the thing apart 3 times in 2 years.
Jul 21, 2009 | Maytag MSD2651 HE Side by Side...
We have a maytag performa side by side fridge model number psb2151gr the ice maker is not hooked up but it creates ice and collects in the bottom of the freezer and runs out on the floor how do i fix this
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Buzzing sound from interior light bulbs
sounds like you have an issue withthe electronic control board locates behind refrig next to the compresssor, in a white housing
Dec 30, 2008 | Amana ABB1927DE Bottom Freezer...
Dispenser
Sounds like a control fault on the microswitch to activate the ice and water line. Access to this is immediately behind the ice dispenser section (just above) on the freezer door. Normal access is two screws located behind the removal drip tray section. Either that or the control board for the ice dispenser as you are not getting water as well. Before taking this section apart though you should hear a buzzing sound when you activate the chilled water, if you do then you may have a water supply problem. Hope this helps.
Mar 13, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Washing Machines Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
