Question about Dell Dimension 8400 PC Desktop
Dell 8400 new memory
I recently upgraded my memory from 1GB to 2GB. I took out the two 512mb and replaced them with 2 1GB. But now the computer seems to be running slower and programs freeze up for about 20 seconds now with the new memory then with the old memory.
Can someone help me with this.
Thanks
  • 50 Answers
Please try the following steps
1. unplug 1 GB memory from your system and try starting the computer with 1GB ony. Check the computer speed does it make any difference or not. Do the same step with other 1GB memory. if there is problem with any memory stick you will come to know using this mathod. If system is working fine with both memories then put them togather and check the system performance
2. Increase vertual memory. To do so please ref the below link
http://www.aumha.org/win5/a/xpvm.php
if u need help what are the component in your system please see the below link
http://support.dell.com/support/edocs/systems/dim8400/SM/techov.htm#wp1060221
if this information is helpful in fixing your issue please vote
Posted on Dec 31, 2008
    President:
  • 948 Answers
If you are using Windows XP, go into your control panel, double click System (from classic view), and look towards the bottom where it says "Processor x.xx GHz, x.xx GB of RAM" and make sure your 2.00 GB of RAM is recognized by Windows. Next I would make sure you are using 400- or 533-MHz DDR2 unbuffered SDRAM. If you are, try removing one of the two modules and see if the computer runs smoothly. If it does, I would install a different brand of memory.
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
Can't upgrade memory past 1gb when max is 2gb
I have the same issue with my laptop. I have not been able to get the laptop to accept 2gb of memory yet, but I did find something that works. If you put your 512mb memory that works in the laptop and then add a 1gb stick in the second slot it works. Or at least it did for me. It's better than nothing. I am still trying to figure out how to get it up to the 2gb max. Will add a solution if I figure it out.
Feb 08, 2009 | Toshiba Satellite A105-S1712 Notebook
I would like to change my hard drive
If you are looking to save just a "small" bit of $ .. 2 - 1GB sticks should be cheaper .. but what is the current configuration . is it 1 - 1GB or 2 - 512MB or 4 - 256MB?
You have the option of IDE or SATA drive so either is an option .. You may want to get a drive copy utility and just "clone/ghost" your current to the new drive and then swap it to master and GO
Dec 26, 2008 | Dell Dimension 4600 PC Desktop
Dimension 2400 is at 1.5MG - will not go to 2.0MG per manual!
yeah thats a normal issue with the dimension 2400 as the older bios only supports a max of 1gb of memory you will need to go to the dell website which ive linked below and get the bios update which will give you support up to 2gb-pc3200 ddr memory
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Asrock 775VM800 Motherboard
Computer keeps rebooting
you either have a bad memory or bad memory slot!
good luck
please mark the post with a fixya
Feb 19, 2008 | Computers & Internet
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 8400 PC Desktop Logo
100 people viewed this question
Alun Cox
