Question about RCA RT2250 System
Need Universeral Remote Code For RCA RT2280 Home Theather System
Help,
I Need Any--Universeral Remote Code For My RCA RT2280 Home Theather System, To replace the org remote control,
I have A New One For All Replacement Remote --Which has nothing listed for Any-- RCA Home Theather Systems,
I also have 4 other remotes for Sony TV Set and RCA VHS Recorder Etc... That Can be Programed,---but none list any codes For My ( RT2280 500 Watt,--RCA Home Theather,) Any One have a code ?? ....Thank You All,
Mr Grove in WV ....On: 12-31-2009
  • Anonymous Mar 08, 2009
    RTD209 same issue
  • 112 Answers
SOURCE: code list
here are the codes for progamming your remote to zenith televisions...
000, 001, 004, 051, 083, 151, 152, 153, 154, 210, 217
hope that helps
Posted on Jan 21, 2008
SOURCE: RCA RCR311W remote
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Posted on Jan 24, 2008
VOTIT
  • 2071 Answers
SOURCE: I bought your RCA universal
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
SOURCE: lost my code book for rca univ remote
Well I know this is a few months late but go to www.rca.com/codefinder to find the codebook. Usually the model number of your remote control is on the inside of the back lid. Just take it off and flip it over.
Posted on Sep 01, 2008
SOURCE: rca remote control code list
OK GANG: HERE GOES, I PURCHASED A RCA REMOTE (RCR312W), 3 CHOICE FUNCTION.
SAT-CBL...TV...VCR-DVD.
I HAVE 2 DIFFERENT TV'S, DAEWOO TV AND A PANASONIC TV/VCR. THE REMOTE HAS
WORKED ON BOTH SETS. I DROPPED THE REMOTE WHEN IT HIT THE FLOOR THE BACK
FLAP HOLDING THE BATTERYS KICKED OFF AND ONE BATTERY FELL OUT. I WENT NUTS
FOR 2 DAYS TRYING TO GET THE CODE FOR THE DAEWOO. TODAY 11/14/2008 A FRIEND
GAVE ME A PANASONIC TV/VCR 20". AGAIN I TRIED TO FIND THE CODE, DIDN'T WORK OUT EASILY, AGAIN DRIVING ME LOONY TUNES IF YAA KNOW WHAT I MEAN.
HERE IS THE SKINNY: SOLUTION TO YOUR PROBLEM !!!! IT DOES WORK.
1, TURN ON THE COMPONENT YOU WANT TO PROGRAM.
2, PRESS AND RELEASE THE COMPONENT BUTTON ON YOUR REMOT THAT CORRESPONDS TO THE COMPONENT YOU WANT THE REMOTE TO OPERATE.
TV, VCR, ETC... THE ILLUMINATED ON-OFF BUTTON WILL TURN ON AND STAY ON.
3, NOW PRESS BOTH BUTTONS ON-OFF AND TV, OR: ON-OFF AND CBL. WHAT EVER.
THE ON-OFF BUTTON ON TOP OF THE REMOTE WILL TURN OFF, KEEP PRESSING
AND IT WILL COME BACK ON AND STAY ON. RELEASE THE BUTTONS,BOTH.
ON-OFF WILL STAY ON NOW.
4, KEEP POINTING THE REMOTE AT THE COMPONENT, THE REMOTE AND THE TV
NEED TO TALK TO EACH OTHER,(MAKES SENSE.)
5, GO TO THE BOTTON OF THE REMOTE AND PRESS THE "PLAY" BUTTON,
RELEASE. "" KEEP PUSHING THE PLAY BUTTON EVERY 5 SECONDS,
UNTIL THE TV TURNS OFF"". OR THE VCR, OR THE CBL, WHATEVER YOU ARE
PROGRAMING.
6, NOW: PRESS AND RELEASE THE "REVERSE" BUTTON, THIS IS AFTER THE TV
HAS TURNED OFF. TV SHOULD TURN BACK ON WHEN THE "REVERSE" BUTTON
IS PUSHED.
7, IF THIS WORKS THE LAST STEP IS TO HIT THE "STOP" BUTTON,
THIS WILL SAVE THE SETTING. REMOTE SHOULD BE PROGRAMED AND TURN
THE TV ON AND OFF. YOU DON'T NEED THE SILLY CODE NUMBER, THE REMOTE
DOES THE ACTIVE PROGRAMMING AUTOMATIC.
HOPE THIS HELPS YAA ALL... "PEACE".........OKIE
Posted on Nov 15, 2008
Rca blu ray home theater rtb10220 why did my remote quit working?
Probly moisture damage. Take it apart and check board for damage. U can also smell the board for a burnt smell.
Jul 24, 2014 | RCA Televison & Video
Hoooking up surround sounds with optical cable surround system is RT2280 AHHH please help my husband is driving me crazy to get it fixed and he cannot figure it out. Superbowl must be in surround sou
Make sure the digital setting (optical/coaxialor analog)is correct.
If youre connection is differet from default setting
1.select the source
2.press function
3.rotate multi jog to toggle among optical/coaxil/analog to match
yuor connection.
your selection will be stored automatically.
every time you press the source button the input setting(dvd/opti)
will be show on display.
heres a link to the manual go tto page 21 advanced settings.
http://www.google.co.uk/url?sa=t&rct=j&q=surround+sound+RT2280+AHHH&source=web&cd=4&cad=rja&ved=0CEMQFjAD&url=http%3A%2F%2Fsupport.radioshack.com%2Fsupport_audio%2Fdoc66%2F66651.pdf&ei=G2QMUbKqMOOY0QWJlYBw&usg=AFQjCNG2gc-bExNRynH2JEV22sR-L_ggDg&bvm=bv.41867550,d.d2k
Feb 02, 2013 | RCA RT2280 System
No sound from tv, dvd, cable. Speaker test does work. Sound stopped suddenly when channel was changed.
What does this mean: "when channel was changed"? TV channel?? Would that mean a remote command was issued? How about FM (no external cabling)?
Page 23...
http://www.retrevo.com/support/RCA-RT2280-Home-Theater-Systems-manual/id/402ag600/t/2/
Sep 02, 2011 | RCA RT2280 System
I have RT2280. Audio levels used to be 1-50, now
Sounds to me as if someone may have gotten into the menu to adjust the individual levels of each loudspeaker and cranked some of them way up. As to why the "main" volume level goes from1-20 now as apposed to 1-50, you got me there...
Is there a reset button or equivalent on the remote or the unit? Try that. Try unplugging the unit for 15 minutes...
Here's the owner's manual:
http://support.radioshack.com/support_audio/doc66/66651.pdf
See page 21 for advanced volume control functions...
Mar 04, 2009 | RCA RT2280 System
Buzzing sound through the speakers
Sounds like you are getting interferance from something like a cordless phone, TV, Computer something like that.
Feb 08, 2009 | RCA RT2280 System
Rca rt2280 home theater
hi my son lost my tv remote for my toshiba tv, i was hopping my rca universal remote could adapt to my tv but i do not know the codes how to program it does anywhone have a solution thanks.
Feb 12, 2008 | RCA RT2280 System
RCA RT2250 System Logo
1,027 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
