Machine started drum was turning but it stopped all together after 10 minutes leaving water in drum the spin finished light came on yet it hadnt spun
Stopped in the medium of a cicle
The beko washing machine does not work anymore.....even when you try to cancel the wash it doesnt work,.....any sloutions
Hello. The control unit, can't remember what it is called, may be going bad. In the older top loaders it is easy to replace. Remove the knobs, and screws around the cover plate. Take a picture of the unit so you can see where all the wires go. Follow maintenance manual if you have it. Carefully disconnect and get a replacement part, name and number are either on the unit or under the cover plate. Reconnect all of the wires and it out. I've replaced a couple. Good Luck!
