Question about JVC AV-32820 32" TV
JVC AV-32820 tv SMPS replacement ?
I have the white horizontal lines on the upper 1/3 of the screen.
How much do you think a tv repair shop would charge to replace the smps (parts and labor) ?
Is the smps something that can be easily snapped in ??? I work on pc's a fair amount.
John
My email is arnek@bellsouth.net
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
MY TV HAS A PROBLEM, WHEN I TURN ON THE POWER SWITCH THE TV IS ON BUT ONLY THE SOUND IS HEARED AND THE SCREEN OR TUBE HAS A DISPLAY OF SEVERAL HORIZONTAL LINES IN COLOR AND IT LOOKS SCROLLING UP DIRECTION,...
something it either the video or horizontal circuits is defective..what you are seeing is the horizontal retrace lines...this problem can be caused by a capacitor that has become defective, or several other components...i suggest taking it to a service shop as this problem in not usually user repairable
Jun 11, 2011 | JVC AV-36950 TV
My JVC AV-32820 is locked and I do not know the code to unlock it. Is there a general default code that I can use to unlock my t.v.?
How can i unlock my jvc av 32820 it turns on but is locked in one channel and i do not have the remote that came with the set can i use my cox remote to set the menu on tv
Dec 25, 2010 | JVC AV-32820 32" TV
Our JVC AV-32F703 has a black screen when we turn it on. The sound works fine. What could it be? The tv was purchased in Jan 03
try up the screen bottom in the fly back. if yoy see a white horizontal line the tv have a cold solder in vertical ic or is bad.
Apr 14, 2010 | JVC AV-32F703 32" TV
JVC AV-27920 white horizontal lines on top of the screen
YES THERE ARE 3 CAPS. 2 ARE SMALL ONE LARGE IN THE VERTICAL CIRCUIT. 1 OR 2.2 uF AND A 1000uF. ALL ARE VERY CLOSE TO THE VERT. IC AND YOKE PLUG. PHYSICAL EXAMINATION SHOULD SHOW WHICH ONES DRIED OUT AS THE HEAT SHRINK WRAPPING AROUND THEM PEALS UP. ALSO WHEN YOU UNSOLDER IT YOU MIGHT SMELL "STINKY FISH" AS THE ORGANIC ACID INSIDE IS LEAKING OUT THE BOTTOM. LOOK FOR BROWN OOZE ON THE LEGS ALSO.
Dec 27, 2009 | JVC AV-27920 27" TV
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
JVC AV-24F702
well i suggest just replace all of them around the vertical output so u dont have to replace just the only one n in the future u have to replace the other one.
Nov 06, 2007 | JVC AV-24F702 24" TV
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Televison & Video Logo
56 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
