Question about Sony PlayStation 2 (PS2) Console
Tv will not recognise my ps2.
Ps2 is working, i put the adapter in the back and the other end in the ariel socket in trhe tv, it automatically puts my tv into sleep mode, is there a certian channel i should have it set on or something i should be switching on or off. I have had the ps2 for many years but have recently moved house and cant remember how to connect it. thanks.
This usually happens try putting it on av1 or 2 it might work or continue trying to make the ps2 screen show that's what i did when it wasn't showing my ps2 on the tv also try putting it on the normal tv channels using the remote that came with your tv and then scan to see if your ps2 screen comes up.
Posted on Jan 01, 2009
My playstation2 says please insert a ps2 or ps format disc and there IS a cd
Tv has no signal
The TV you are trying to connect to may be an older type and not a DIGITAL receiver. The old ANALOG type no longer work with the Digital applications unless to have a CONVERTER BOX.
Dec 22, 2013 | Televison & Video
We are trying to connect a panasonic digital receiver TU-CT20A to a panasonic TV Model TX 76PW60A without success.Could you kindly guide us through the procedure.Many thanks.
Put the main aerial into the receiver aerial socket,then connect the fly lead (the one that has male and female ends) to the other socket on the receiver,then put the other end into the tv.
Then put one end of a scart lead into the socket on the receiver marked tv,then put the other end into the scart socket on the tv,either in av1 or av2.
Then turn on the receiver,the tv should automatic go to the av channel,then you will just need to tune in the receiver.
Hope this helps.
May 11, 2011 | Panasonic Televison & Video
How do I hook up my PS2 to the Internet?
make sure you have the Ps2 network adapter on your PS2. After that just simply connect and Ethernet cable to the back of the adapter. The other end of the cable goes to your router of course. Turn on router make sure you have a connection on your computer.( e.g. internet works) Then turn on your ps2, put in a game with online capabilities. Go to the online section of the game and create your account. And there you go, you should be connected. Keep in mind some ps2 online might not work they might of taken the servers done since PS3 is now primarily used online.
Apr 18, 2011 | Sony PlayStation 2 (PS2) Console
Hi, I'm looking for a little help. I've looked out my old NES Nintendo, plugged it in after a good 10+ years in storage, I've got the RF cable plugged into the RF jack socket on the back of the console and...
If you are using the RF cable you should be able to see video as long as you are on the right channel set from the RF cable, if that isn't working then just try plugging in the video cables and see if it is just the RF cable not working.
Dec 20, 2010 | Nintendo NES Console
How do i conect my ps2 on a lg hdtv its got no yellow plug in
your ps2 came with an adapter to change mono plugs at the end of ps2 leads into a scart socket
check for any conections on side of tv
Dec 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Sound but no picture on either SCART socket inputs
open the tv and check for dry joints on the jacks of AVS, if no dry joint is found
the ariel in put is different from AV inputs
change the AV in IC. AT THE W/SHOP
Apr 25, 2009 | Goodmans 257NS 20" TV
Ariel socket in tv has broken
The best thing is to replace the signal board, that costs $24.
Check here for the part : Polaroid Replacement TV Parts
You find the part on Ebay here.
Part number is 200-013-JK371-1AH FLM-323B
Oct 24, 2008 | Polaroid LCD-2050 20 in. Television
Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
Oct 03, 2008 | Panasonic Televison & Video
Please help me.
The input AC socket of your PS2 is loose for which you can replace only this socket if some dry solder is not there. Note: This AC Socket is totally seperate from Motherboard.
Sep 04, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
155 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
