Sharp DAB/FM radio model no FV-DB1E(S) display not showing text
My Sharp DAB/FM radio model no FV-DB1E(S) display is not showing the text data.The back light is illuminating (both levels) but the text cannot be seen clearly (viewing 90 degrees to screen plane), however if I view the screen at a slight angle (approx 10 degrees to screen plane) I can just make out the text as 'clear' digits against the blue background. Could this be sorted or has the display failed. Any advice would be appreciated, thanks John
  • Colin L.Swan Dec 31, 2008
    Same DAB/FM radio - Sharp FV-DB1E and it still works but text lettering is now very faint and can only be seen/read in dark conditions!! Background blue lighting still has the 2 levels.
    Any ideas anyone??
  • mmmhdonut Apr 14, 2009
    My FV-DB1E(W) is not showing any text at all and just glows blue.
  • 71 Answers
SOURCE: DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Posted on Feb 26, 2008
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
HOW DO I GET MY CDAB5IR STEREO DABRADIO TO WORK
The first thing is to consider what DAB signal quality you have there. It might not be strong enough. Digital radio is not like AM/FM, it simply goes off altogether if the signal is weak.
I would take it to the shop and ask for assistance, or get next to a DAB radio which does work well. Then recheck things like settings, tuning, and a good battery in it (I think that model is a smallish radio?)
Nov 04, 2013 | Audio Players & Recorders
SONY XDR-S55DAB Stack at display : DAB WAIT
Solution seems to be do not buy small Sony DABs, or any small ones. I have the XDR-S56DBP and have same problem. Was also cursed with 'no ensemble' error. Even worse than the Pure one I had before which lost all of the DAB facility and now only functions as an FM radio. I had a good medium sized Roberts one, but power cable split and I can't find a suitable replacement.
Apr 28, 2009 | Sony Audio Players & Recorders
DAB RADIO MATSUI MATCR 515D- ILLUMINATED TIME/STATION DISAPPEARED - NO RECEPTION - MUSH CAN BE HEARD IN SPEAKER
It is possible for the display to be set so low that it is not illuminated at all. With the radio off (i.e. the set must be in standby), press and hold TUNE+ to raise the brightness level.
If this gets the display back, you may be able to see what has happened to the tuning. e.g. check whether the tuner is set to FM or DAB etc.
Apr 29, 2008 | Audio Players & Recorders
Buzzer instead of radio
I have this radio too and from what I have read in a review on amazon suggests alarm does not tune to DAB only FM - very annoying! Contacted Goodman customer care and they suggested it was a problem with a component but maybe it is just the design.
Mar 16, 2008 | Audio Players & Recorders
How to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Feb 29, 2008 | Audio Players & Recorders
Feb 22, 2008 | Audio Players & Recorders
353 people viewed this question
 Grubhead
Grubhead
