Question about Panasonic PT-44LCX65 Television
Redish orange Color Spot
I have a PT-44LCX65 and it is approximately 18 months old and a couple of weeks ago a roughly circular area in the screen began appearing more red/orange than the rest of the screen. Now, aside from time sthat the screen is all black or mostly balck, the spot is almost always visible. I haven't really taken any steps to resolve the issue and the buld has never been replaced. I am assuming though that this isn't a bulb issue as it is just a spot near the center (just slightly higher than the center) of the tv. Thanks!
  • 3 more comments
  • Martin Lassen May 06, 2007
    Actually, it is more of a redish pink color spot now.
    TIA
  • Madmoma Dec 17, 2007
    We have three spots on are TV there is a green spot bottom left hand side,a red spot on the right side edge, and a purple spot close to the middle the size of a golf ball.
  • woeful 2 Jan 04, 2008
    I have the same exact problem as woeful. TV's about two 1/2 years old. The reddish orange ball is about the size of a silver dollar, and appears mostly in light colors, and some greens.
    Woeful 2
  • hddunc Feb 05, 2008
    I have a red dot on mine and it's 22 months old...for what we all payed for this item it should last longer, I would like to see Panasonic address this issue they have to know it is a problem....this is probably my last Panasonic.....
  • corbrwl Jul 19, 2008
    Same problem here. Have had the tv for 3 years with no problems. Red blob/dot the size of baseball is now showing up. Thought this might be the lamp, but the lamp light is not coming on. Would hate to spend $150 for a lamp when that's not the problem.
    Problem Solver:
  • 12 Answers
Ok...once and for all I will explain the fix (in detail...which has been missing)...
1) Firmware updates do not fix this problem. I had this problem, and updated my firmware to the latest versons without success. Also, cleaning the light engine (or any other part) does not fix this problem. If you cleaned your TV and your problem disappeared, you had a different problem.)
2) This repair requies a special tool from Panasonic. The tool is part number LSUQ0100. It is light grey in color, and is roughly 7" x 5" x 1" in size. It has diagnostic lights on it, and a button to press to start the procedure. This tool is used to reprogram your EEPROM. Again, this is VERY different than flash upgrading your firmware.
3) To repair the TV, the repairman must remove the lower back of the unit and plug the long, 5-wire connector (5 individual wires terminated to one female connector end - reminds you a bit of an old-style CD-ROM audio cable used in computers) into a male recepticle on the light engine.
4) The procedure takes roughly 6-7 minutes to complete. The TV remains on during the procedure (yeah, I was a bit surprised too). About mid-way through the procedure, your colored ball-shaped blotches will just disappear....no on-screen progress bar, no bright flash, the spots just disappear in the blink of the eye.
5) CALL PANASONIC!!! They are standing behind these TVs, and are covering these in-home repairs free-of-charge - EVEN IF YOUR TV IS OUT OF WARRANTY. Mine was out of warranty by over a year. The Panasonic rep was very kind, but did explain that this is the only repair for these TVs that they will cover out of warranty, as it was a defect in the manufacture of the unit - all other repairs are at the expense of the customer.
Good luck to all - I hope this helps some of you!
Cheers to Panasonic for standing behind their products like this....you don't see that very much these days!
Thanks,
Chris
Posted on Sep 25, 2008
I have the same result as ChrisM. I emailed Panasonic about the issue and they replied with a request for more info regarding the serial number, date purchased, etc. After I supplied this, they called me and gave me the number of a local TV repair shop. I called the shop and they set up an apapointment. My wife was home when the came to the house for the repair, and she said it took about 15 minutes including diagnosis and repair. Evidently there is a component that has been corroding on many of these units, so they replace the component and it works fine. Since they have had so many problems with this issue on this model, they did the repair for free, even though I was two years out of warranty! Thanks Panasonic, I'll definitely buy from you again!
BC
Posted on Oct 26, 2008
It is the color computer.
I was fortunate and had bought the extended warranty, so I upgraded to a 52" for the same price when Panasonic decided they wouldn't fix it under warranty.
BTW, 6 months later, I went back to CC and found my 44" on the floor waiting to be sold as an "open box". How do I know it was mine? It still had my name & address sticker in 2 of the 3 places I put it when I anticipated it being taken to a repair shop.
Posted on Jun 21, 2008
My parents just developed a similar problem. They have a 44" Panasonic PT 44LCX 65 and have only had it for just under 2 yrs. It is a red spot about 4 inches in diameter in the picture.
I think we all need to call Panasonic and tell them to fix our problem or we will go on an internet rampage to stop people from buying their products. This type of problem should not be occurring so soon in such expensive units.
Posted on Mar 25, 2008
You proubly have to replace the "Light Engine" panasonic has a hard time keeping thes in stock. I neede one took about 60 days to recive it.
Posted on Dec 13, 2007
I have the same red spot on mine and have had it for about 3 months, the TV is 26 months old. It is roughly the size of a baseball, and depending on the color of the image in that spot can be more or less visible at times. It looks like someone is holding a flashlight behind the screen. I'm open to any ideas as well.
Posted on Aug 21, 2007
  • 3 Answers
I don't have a sollution, but a similar problem. It started with a light green spot near the top center (actaully makes for an interesting sci-fi sunset on many ocassions), and now a blue one appears on the bottm left. I am waiting for the red one to appear on the bottom right for symetry. I am under the impression that, when the bulb needs replacing, it begins to go dark, which makes sense, so this does not seem like a bulb issue, but maybe I am wrong. The set is almost two years old. Any help would be appreciated.
Posted on May 24, 2007
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Over past couple of months the tv has gotten 2 red spots in the lower right hand corner of screen about an inch in diameter, and recently a green spot in center top third of screen that is about 2 inches...
Unfortunately your light engine(also know as optic block) may need to be replaced. If your tv is out of warranty, it will probably cost around $1000 to fix. There is a slim possibility that the optics lens could have dust on it and a tech could clean it for much less than that. This is a very common problem in any dlp tv and they are all expensive to fix. I've replaced several of them at our shop, but about half of the customers won't have the tv fixed and will get a new one. Good luck!
Jul 30, 2010 | Panasonic PT-44LCX65 Television
Green blue and red spots across screen. I changed the bulb a few months ago.
You need to contact a serviceman. Your light engine needs replaced. Panasonic requires prior tech authorization for parts order fulfillment such as this. PN: TZSC03045 It will be costly, roughly $800 with $250 core charge. Labor and trip fees are another thing altogether. I hope this helps.
Mar 21, 2010 | Panasonic PT-44LCX65 Television
Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
Panasonic projection lcd pt-44lcx65 pink wavy lines
The problem is the computer in the TV is set to hold data for 2500 "On/Offs" Once you turn the TV on and off 2500 times, the dots start to appear as the computer cannot store anymore date. Call Panasonic, they will send a tech to your house for free and reset the computer and update it at the same time from 2500 to 1 million on/offs so it wont happen again. It takes maybe 10 mins to complete.
Hope this helps.
Mar 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Purplish/blue spot on screen
Howdy,
The problem is with the EEPROM in the TV that needs to be reprogrammed. But you need to have the proper Correction Tool (LSUQ0100).
I don't think it's available to the public. Call a Service Company, but make sure they have the “Correction Tool”.
Thanks for using FIXYA, big IRISH.
Jul 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Green Spot
set your tv to original default factory settings.
then apply also good resolution.
your problem is most of solved
Mar 24, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Spots on the screen
Your problem could be dust or dirt on the lens inside the reflection cavity or the problem could be the light engine. If the problem is the light engine, thank god you have an extended warranty as the light engine alone cost somewhere around 1000 buck. Good Luck.
Apr 27, 2007 | Panasonic PT-44LCX65 Television
Panasonic PT-44LCX65 Television Logo
316 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
