Question about Yamaha RX-Z1 Receiver
RX Z1 lose sound, turn off/on, 2nd click not happening, no sound
I had the other problem hear and it went away. AFter 4 years of heavy use, about 8 mo ago, sound went off, turned unit off, back on and walla 'I got sound'. I didn't use it for months and swapped optical cable with cable box optical and got sound. Now, 3 months later, when the sound goes off, and I turn unit off and then on, I get the first click in the circuitry, but the second and the speaker indicators do not turn back on. I am ging to disconnect all speakers and see if the unit cycles with speaker indicators coming back on. If so then I may have a speaker drain issue. So, I will add pairs of speakers and see if the units cycles. If at some point it does not, then I may have a short on that channel or a speaker problem. To rule out the speaker I can put them on a working channel and see if they fire up. It will be time consuming. bjmallard_at_aol_dot_com for any similar issues and comments.
SOURCE: Yamaha RX-V1500 Shuts down after 2 seconds
This set is getting old and is in the Archives section of the Yamaha consumer guide area. But, you can still download the owners manual if you need one. If it is going into protection mode even when there are no speakers connected OR when the sound level is very, very low or zero it is not good news. Yes, unplugging the line cord will cause the protection system to reset itself. But, if it shuts itself off again soon after rebooting it is a sign of bad grease in the output stages -- in all probability. Let me explain: The audio output transistors are mounted to a large heatsink which keeps them cool during operation. They are electrically isolated from touching the heatsink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set). That is the most common cause of your symptoms. However, there are several other possibilities, but I give this explanation a 90% probability based on my experience.
Posted on Jun 17, 2007
SOURCE: yamaha rx-1500 av receiver
some times the speaker cables are touching, double check, I had this with my amp and it kept turning itself off
Posted on Jun 25, 2008
SOURCE: Yamaha Receiver (rxv3000) has intermitent power problem
Most, but not all of the voltage regulators are cooled by the same heat sink
that the output transistors are attached to and get overheated when you crank up the volume. Although this unit has a cooling fan, after some time the heat sink gets HOT and will age these parts. There are also a group of three current limit/ voltage drop resistors supplying one regulator that will give up too. This is not for most DIY folks. Repairs are available in certain parts of the country. I know of one you can ship the unit to and get it fixed like I did.
Posted on Sep 17, 2009
SOURCE: Yamaha HTR-5940 won't stay on after thunderstorm
I have the same problem as you but no thunderstorm. Mine happened after I connected speakers with the unit operating and had a speaker wire short at the back of the unit. Got a whiff of smoke and now I have that DSL1U unit clicking same as you. Did anyone suggest a fix?
Posted on Apr 04, 2010
SOURCE: static crackle on yamaha 6030 in 5.1 ..static
I have this exact same problems. It depends on the signal format somehow I've noticed. It's extremely frustrating. I'm wondering if we just got a bad 5.1 processor?
Posted on Jul 30, 2010
RX-8 & DSC
Hi Melissa,
I had a similar problem with my 2005 RX8 but didn't try using the DSC button. I had to have my engine rebuilt....I'm in So Cal and found a great private mechanic, are you local???
May 14, 2014 | 2005 Mazda RX-8
Have a KS55 mixer that has never been used -- sitting for about 4 years and went to turn it on and it makes a noticeable clicking sound in the lower speed settings (1-3). Noise goes away (or is not...
A lot of things can happen to a piece of machinery after 4 years of idling time.
Dust, moisture, rust and dry hard Grease are just few of the problems. The
good news is it's not hard to put it back into service again. Obtain a copy
of the Repair Part List from Kitchenaid.com and start opening up the mixer.
Vacuum all dust inside, remove dirt and debris. Open up the Transmission
Housing and scoop out of the old grease. Use fresh Kitchenaid Food Grade
Grease for all gears including the Agitator (part of the Planetary Assembly) and
you are good to go.
Jun 09, 2011 | KitchenAid K5SS Heavy Duty Commercial...
I have a side by side Kitchenaide ksrs27. I went away for approx 3 mo and upon returning my refrigerator isn't cooling. The condenser fan at the bottom rear works and coils do not apprear excessively...
Take the contents out of the freezer and behind a panel inside is the evaporator it is most likely iced up. Unplug it. I'd take a hair dryer and melt the ice. Try that.
Jan 27, 2011 | Refrigerators
Nothing happens. power on,can hear click
I had the same problem, but I saw the events leading to it. I was watching TV, went to help the wife, heard a pop, came back to find the TV off. Turned it on, heard the same click you described. I believe you need a new bulb. Mine lasted around 2 years of heavy use. Bought two on ebay. Make sure to consult your manual for the particulars on the bulb.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
87 mazda rx 7 n/a cutting out at 4000rpm
Sounds like plugged up pre cats, my NA had the same problem I got a Racing Beat header that eliminated the pre cats and it went away. I've also seen them on eBay for cheaper. Either way you can't lose the stock header is like a cast iron stove attached to the engine it's heavy and massive.
Dec 03, 2008 | 1987 Mazda RX-7
Rx v2095 receiver - No sound from either front main speaker
I have had similar problems on a Denon. I suspect your DSP needs repaired and/or replaced. Need to contact authorized Yamaha repair shop or a competent local repair facility. I have a Yamaha RX-V2092 which is similarly designed. I have had it for 10 years. Hope this helps.
Nov 29, 2008 | Yamaha RX-V596 Receiver
Losing digital picture with HD TV
First, hide the remotes so that the TV cannot "see" it. If the problem goes away, it's the remote. Other than that, it sounds as if the receiver is faulty...accordianman
Nov 02, 2008 | Yamaha RX-V861 Receiver
Fuji Finepix Z1 Zoom Error
I saw another post in this forum were someone suggest banging it on a table a couple times, not to hard that you'd dent it but a good enough bang. Worked like a charm! I tried the trigger and slide method but while the error message went away the zoom wouldn't focus. Try banging it, it sounds bad but it worked wonders!
Mar 06, 2008 | Fuji FinePix Z1 Digital Camera
Yamaha RX-Z1 Receiver Logo
71 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
