Question about Panasonic TX-32PL10 32" TV
Panasonic TX-32PS5 I have just reconnected my satelite box and DVD through a Wi-Fi connection to use on another TV. now the picture keeps going off for a second or two and EC2 flashes before it comes back on again. In the process I have reduced the SCART wires to 1 as I followed the connection instructions.
  • 883 Answers
Possible that your provider has detected a 'leak' and sent disabling codes
Posted on May 20, 2007
SOURCE:
Unable to reconnect to wi-fi
If you have not done so already, reset the player to factory settings and try again. If an ethernet cable connection is available, use it to get the best connection speed.
Dec 12, 2013 | LG DIGITAL/AUDIO/VIDEO Lg Bp330 Blu-Ray...
Onkyo TX-SR604: Video in from cable box has taken increasingly longer to display a picture.
I would at least disconnect all units from power for a while and then reconnect to allow the units to reboot.
Oct 30, 2012 | Onkyo TX-SR604 Receiver
Panasonic viera tv. Connection error 007
My TV set is PANASONIC VIERA 32AS600 series. Received error 007, canot connect to wi-fi network. In wi-fi settings, change to MANUAL, check proxy settings: delete all letters/characters in proxy address (leave blank), proxy port is not critical. Check your connection. Good luck !
Jul 30, 2012 | Panasonic Televison & Video
Iv been given a panasonic TV TX32PS5. But the menu and set up is not in english ? i have no manual for it so i don't know how to change it back. I would be very grateful if you could help me please. Thank...
Try downloading your manual at the following link:
www.pdf-manual.com/user-guide-instruction-owner-manual-panasonic-tx- 32ps5-10202.html
Click on DOWNLOAD PAGE at the bottom.
Good luck and post back if this helps.
Jan 28, 2011 | Panasonic Televison & Video
Just bought a Panasonic TX-P42G10B 42in 600Hz Full HD with freesat HD built in. We currently have Sky +, but i was unwilling to pay the extra a month for the sky HD service. Therefore this tv seemed fine....
Use a good quality scart leads for starters.
connect oon end to tv and the other labeled tv on sky box. The other is labeled vcr. connect another lead from vcr or dvd to that connection.
If you have a hd dvd player or Bluray, then buy a HDMI lead and connect straight to one of the HDMI inputs on the tv. I know this is late but i hope it still helps you and anybody else who may read this.
Dec 28, 2009 | Panasonic Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Don't want to use receiver to turn Plasma on via Verizon DVR
You can not have a signal from cable/satelite TV when reciever is OFF.The only way is reconnect by using defferent setup configuration to illiminate the receiver.In that case you well see just regular Tv program but you should connect antena to your TV.
Apr 17, 2009 | Onkyo TX-SR705 Receiver
How to get older panasonic tv working in New Zealand
You will need to have a tuner fitted which will work with the local frequencies. Is New Zealnd NTSC?
Jan 30, 2008 | Panasonic TX-32PL10 32" TV
Picture problems
This could be an unshielded cable problem. Also magnetisam from speaker(s)(i.e. subwoofer) could affect signal from satelite antenna, or could affect satelite receiver if it's near.
Oct 01, 2007 | Panasonic SC-HT40 System
Panasonic TX-32PL10 32" TV Logo
119 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
