Question about Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz / 1GB DDR / 200GB HDD / DVDRW DL / DVD-Rom / Flash PC Desktop
I have a gateway GT4015E and the problem is when I turn the pc on, hard drive light tuns on solid and goes off after a while, fan runs,dvd,cd opens,but no beeps,no bios nothing on screen
  • mwit465
    mwit465 May 11, 2010
    Might be too obvious, but is the monitor plugged in correctly and turned on?
    Problem Solver:
  • 21 Answers
Open up your pc case unplug the hardrive from the motherboard and plug it into another sata port
Posted on Dec 31, 2008
Windows 8 Gateway desktop trying to load Win7. I
Hi
You can try with Free Boot Managers and Multi-Boot Loaders you can find lot of free stuff available in online. So download and follow the instructions.
OSL2000 is an advanced multi boot manager you can install multiple OS in a Single PC.
Hope this will be helpful
Have a good day.
Regards
NANDU
Aug 28, 2013 | Gateway SX2865-UR11P Desktop Black
Shortly after I turn my computer it turns off
How long is shortly? If it runs and brings up the Windows Desktop and you are allowed to work for 10 minutes or longer then it shuts down, most likely the laptop is overheating. One way to tell if it is overheating is to immediately try to turn it back on after it shuts off. If it will not boot back up, it's overheating. If you let it sit and cool off for a while, then try to boot it back up and it does it successfully, it's overheating.Causes of Overheating:1) Dust all inside the computer. Fans clogged with dust, dust around the vents.2) Fan not working3) The Thermal Past around the CPU has dried up or is too thin the keep the unit cool.When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Mar 31, 2012 | Gateway Computers & Internet
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
Desaster
If the board on a hardrive is bad, it is UNLIKELY that replacing the board will make the drive work. The original may have "tuning" to the disk that a replacemnt doesn't have.
To avoid data loss you would probably have to go to a recovery outfit and pay plenty.
Sep 09, 2009 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
GT5034 has power, blue light on power button, no beep, no boot, sounds like fan running hard. Hard drive light is on for a while and both CD drives green lights flicker. Nothing comes up on the monitor. HD...
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot up.to test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the bios.you might have to flash the bios and reinstall it.to do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at gamecrazy944@yahoo.com or if you got anymore questions.
Jun 29, 2009 | Gateway GT5034 PC Desktop
Gateway computer does not turn on
Without seeing the machine, I'm thinking you have a motherboard problem. But try these troubleshooting steps before throwing in the towell:
Open the case and disconnect the CD cable. Now try it. If it still doesn't work, disconnect the hard drive and try it.
Let me know what happens. I've seen CDs mess up a system like this. I many times will swap out the power supply, but I'm thinking with the lights flashing, its a more serious problem.
Jun 23, 2009 | Gateway 500GR PC Desktop
Upgrade Gateway AMD Athlon 64 Processor 3500+
friend
looks like your machine has two memory modules
1. 256 mb ddr 1
2. 128 mb ddr 1
module of 2 gb in ddr1 are hard to find
but all you can do is take out these two modules and replace with 2 x 1 gb ddr 1 modules
easy...
thanks
Apr 11, 2009 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
Dell deminsion 3000, fans run, hard drive light on, no boot up.
Very possibly you can unhook the hard drive and cd dvd drivers then boot system see if it goes to post try and get to setup if that does not work then you system board problems or cpu problems.
Mar 16, 2009 | Dell Dimension 3000 PC Desktop
Gateway MT6451 Does not turn on
leaving your unit in standby mode is not a problem as long as your ac adapter is plugged in to your ac outlet and to your pc. otherwise, you will have a drained battery. try removing your battery for a few minutes and then insert it back in then plug your ac adapter to your wall outlet and to your pc and leave it without starting your pc. notice the small pilot light at front edge of your laptop, it should be yellowish/orange. wait until this light turns green then you can try turning on your pc.
Oct 23, 2008 | Gateway MT6451 Notebook
Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz / 1GB DDR / 200GB HDD / DVDRW DL / DVD-Rom / Flash PC Desktop Logo
178 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
