Question about Sony Playstation 3 (PS3) Console
Ps3 will no longer work
I can hear it but no picture on t.v. only a blue screen. I recently had Dish Satellite installed in my room and since then I have been unable to play my ps3. I tried hooking it up to other t.vs throughout the house but still has the same problem. What do you think the problem is? I don't think it's the hard drive, could it have possibly been shorted out? Also, I purchased ps3 a lil over a year ago so it is no longer under warranty it ended about 2 weeks ago!!
  • printchik200 Dec 31, 2008
    no they are in and connected properly.
    Problem Solver:
  • 7 Answers
Maybe because your yellow red and white plugs arent in propaly
Posted on Dec 31, 2008
I can't get a picture to come up.
Have you gone into your setup menu on the satellite and changed any display settings? My 60" HDTV was doing similar things and i was not able to use picture format on my controller to get fom zoom to wide screen, and so on. I had to go into my dish menu and go to setup then video and adjust some settings to display the TV resolution ratio. I was not in the HDMI connection menu when the new TV was origianlly installed to my DIsh. Also had to do same thing on my PS3 under settings and video output resolution.
Just a thought!
May 29, 2012 | Panasonic PT-AX200U Projector
I have the mitsubishi diamond screen tv, and the picture keeps cutting out and turning blue. After I turn off the unit and re start it, it works for a bit, then does the same thing again ?
Usually this is due to bad reception. If you are using a satellite dish it can be due to bad weather. Usually the picture will pixelize then turn to blue.
May 28, 2011 | Televison & Video
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
I have a dish network satellite box with an hdtv. It works well with the red/white/yellow cables and the blue/greened cables together but when I use only the hdmi cable I don't get a picture or sound on my...
I definitely hope that you have gotten this resolved, but if not, here are some reasons this could be happening. If you have tried the same HDMI cable on other devices, such as the PS3, then it sounds like the problem is in the HDMI output on the receiver. Have you tried another HDMI cable in a different input on your tv? It could also be the input on the tv. But so far, it does sound as though this is a receiver issue, and the receiver would possible need to be replaced. You can e-mail me if you have any additional questions. My e-mail is becki.barned@dishnetwork.com.
Becki Barned
DISH Network Customer Service
Jul 21, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
I chose the wrong channel on remote it took me to a Dish site whcih I chose to exit - when I did that my picture totally disappeared - could not get it back. It is fine on my other tvs - so I need to get...
Guest
Are you getting a snowy/blue/black screen on your TV? To get your picture back, you need to get the TV back to the correct channel or input. If the receiver is in the same room as this TV, the TV should be on channel 3/4 (normally 3) or an input setting depending on the TV. TV 2 (away from receiver) would be on channel 60/73. If you have the TV remote, put the TV on one of those channels. If you get a picture when the TV is placed on the correct channel, press and release the SAT button. This puts the remote back in SAT mode and will now operate the receiver.
If you don't have a picture, unplug the receiver for 10 seconds from the electrical outlet and plug back in. This will cause the receiver to reboot and re-acquire Satellite signal. i hope this helps.
Ray Calo
DISH Network
Jun 30, 2010 | DISH Network IR Remote Control
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
SATELLITE DISH
Sure you can, if you have Dish Network go to the receiver and turn the TV and receiver on. Then press menu-6-1-1. This takes you to the point dish screen. You will come out with better results using a compass to find the azimuth the dish should be pointed toward and bore sighting the dish by pointing it in that direction. You then will need to move the dish in very minute increments pausing for 15 to 20 seconds after each move to ensure the satellite signal can be found. If you have ran a check switch prior to this and have lost all satellites you more than likely will not receive a signal until you run another check switch and have found the signal of at least one of the orbitals. If this proves to be to tedious and many times it will you can usually find an inexpensive signal pointing device at a store like Radio Shack. Hope this is some assistance to you. Let me know if I can be of additional assistance and thank you for using Fix Ya.
Oct 07, 2008 | Televison & Video
Dish network 119
you cannot satellite sginal from a splitter you will need dp 34 switch or quad LNBF DP HOPE THIS HELPS.
Jan 12, 2008 | RCA DISH Network(r) 311 Satellite System
Dish network box hookup question.
Are you sure that the antenna in isn't threaded? You may be looking at the wrong jack... All antenna inputs are threaded co-axial "F" connectors. If you ARE sure, could you post a pic of the back panel?
Sep 12, 2007 | iLO 2600 Television
Dish Network DVR
You have what is called a diplexer in the back of the the receiver in the front room.It looks like a splitter.If it is put back on in the wrong way you will have a fuzzy screen.look at the diplexer,you will see in/out which would be the input on a regular splitter,then you will have one side that would be one of the 2 outputs that will say SAT,the other side is UHF/VHF.The chances are that when you plugged them back in you had them swapped.Try changing the 2 cables around.If that doesnt work try changing the assigned channel to 68.You can also try doing a auto channel search on the tv in the room without the receiver.this will find the channel that the front room receiver is broadcasting the signal on.Chances are though that your diplexer wires are configured incorrectly.remember,the in/out should plug into the back of the receiver (satellite in)and the UHF/VHF should be going to the other room with the problem and the SAT side of the diplexer should be wired to the satellite dish.GOOD LUCK! rate me with the outcome please.
May 09, 2007 | RCA DISH Network(r) 311 Satellite System
Sony Playstation 3 (PS3) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
