Washer only spins in the rinse cycle
My Maytag LA612 is making a high-pitched noise in the wash cycle and doesn't spin back/forth. It only spins counter-clockwise in the rinse cycle. Sounds like a belt maybe?
    Sergeant:
  • 311 Answers
The top loaders have bad tub seals which allow water on to spin bearing and then gum up everything.take the frount cover and look for water .if so and you have no service contract it will be expensive.aslo google your model to look for re calls
Posted on Dec 31, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Aug 21, 2009 | Maytag Bravos MTW6600T Top Load Washer
The washer quits at rinse and spin dry cycle
I've had the same experience with my Speed Queen washer. Approached the accredited Speed Queen agents for assistance, when tech support was deployed to diagnose the problem.
In the end, I was told that the "timer" went bust. So the wash cycle seems to work 100%, but when it comes to rinse and spin the contacts on the timer don't make contact, and the motor waits in anticipation for it's next command, and that the high pitch noise heard.
Jul 04, 2009 | Speed Queen AWS52NW Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Noise when washer is in spin/rinse mode
most likely its the pump this is a simple repair just lean the machine back and remove the belt. if this machine has an access cover on rear remove it and disconcet the two hoses from the drain pump remove the three screws holding the pump in with a 3/8 scocket install new pump reconect hoses put back cover on put belt on and your done if no access panell on the rear just pop the top with a stiff putty knife at the front corners remove the front cover and the pump is right there on the right front corner remove it the same as rear put new pump on put cover on close top and your done
Jan 20, 2009 | Maytag Washing Machines
Maytag model la612 spins but won't agitate and making screeching noice
from the belt, please fastening the bolt and possibly it lose a little.
Oct 11, 2017 | Washing Machines
Maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
