Question about Whirlpool Duet GHW9150P Front Load Washer
Sour Smell in clothes
Clothes come out of the wahser with a sour smell. We leave the door open when not in use, but does not help. There seems to be mold on the inside of the door gasket. We have cleaned the gasket several times with bleach, but it continues to come back. What do we need to do get rid of the sour smell?
  • 4 more comments
  • mycookie Jan 02, 2008
    I left my clothes in the washer for two days and I can't get the sour smell out. What can I do?
  • Iriquois May 19, 2008
    I'm having the same problem with the sour smell in my clothes. I also wash the washer with clorox as suggested in the manufacturer directions. Does anyone have any suggestions?
    I have the same problem. I have taken the same steps. Does anyone have any suggestions?
  • buddyo May 26, 2008
    Turn up the temp in your water heater to at least 140. It will kill the bacteria that cause the sour smell in the water itself.
  • neilmel Jun 30, 2008
    Smelly odor from the washer.Leaving the door open hasn't helped.
  • Lavamarie Sep 03, 2008
    My clothes never smell fresh, especially the towels. This has been an ongoing problem. Today I opened the washer to transfer the towels into the dryer and they smelled sour. I rewashed them and it was more of the same. I am trying vinegar in the bleach cup, in the fabric softener cup and in the basket itself. The smell is coming mostly from the fabric softener cup. It is disgusting. My next load I will wash will be in bleach. Hope this takes care of the problem!
While cruising around the net searching for some phone batteries, I came across an ad for a product called "Smelly Wash". I was intrigued by the name, and, since I have been trying to help out a friend who has issues with her front loader and water that is very high in iron and other fragrant minerals, I thought I'd take a look.
32 years ago I bought our first washer and the plumber who came to install it recommended SA8. He told me he had taken apart many machines and most were gummed up with the fillers that are in many detergents. Liquid detergents were not as prevalent at the time.
I friend of a friend helped me locate an Amway distributor and I bought SA8 from her for a few years until we moved. In our next home, I found another distributor and continued using the SA8.
Meanwhile, we added three more daughters to the family and I never once used anything but SA8.
Year's later, an older friend's husband (quite ill with emphysema and with severe contact dermatitis, countless allergies, etc.) called me to borrow some SA8 because that was all she could use for his clothing, sheets, towels...
With each move, we have left washing machines behind because sometimes they were "selling" points. My current machine is a 6 or 7 year old Whirlpool frontloader and I have never had "smelly" issues.
I care for my cloth-diaper using granddaughter and have absolutely no problems washing her diapers. I use one small scoop of SA8, and on occasion, a booster if the load is large. That's it. Nothing smells...EVER...even if I accidentally leave a washed load overnight. Every load smells CLEAN, but with NO scent.
I will go to my grave using SA8. I have to give my clothes away because they just don't get beat-up by the machine nor the detergent.
Posted on Mar 22, 2011
  • 34 Answers
Purewasher is new, improved and called Smelly Washer Cleaner.
Odor in towels and clothing is almost invariably being transferred from the washer.
Posted on Aug 04, 2010
  • Paul Flynn Aug 04, 2010
    Leaving the door open makes the problem worse because it dries out the odor-causing residue and makes it harder to remove. To compare washer cleaners go to:
    http://www.youtube.com/watch?v=Ua6OJPn0-...
    After you remove odor from your washer Smelly Washer products also safely and easily remove mildew smell from towels and clothing.
    Do an internet search on "Smelly Washer reviews" or "Smelly Towel reviews" to read how well the product works.
    After the odor is gone you must change your washing habits.
    1. Use no more than 1 tbsp of detergent per wash load. HE washers must use HE detergent.
    2. Stop using fabric softener because it is dispensed in the rinse cycle and coats the inside of the washer with residue that feeds mold and/or bacteria. Dryer sheets or dryer balls are better options. Dryer sheets can also be overused and cause problems. They can be but in half or thirds or even reused.
    3. Using mainly cold water for washing is fine but makes preventive maintenance very important. A hot wash or soak as your last cycle on wash day will help dissolve residue not dissolved by cold water washing.
    4. Many front loading washers have filter/traps that will catch debris. This debris can cause draining problems and mildew odor in your washer. Save money on appliance repair by cleaning it yourself. Consult the owners manual to clean the filter/trap yourself.
Affresh works well...until you wash more laundry. I have just now starting to have this problem. I have had my Cabrio washing machine (top load) and dryer for 7 months now. I seriously think I may be using too much HE detergent and fabric softner...I will change the way I use these and see if that works. Keeping my fingers crossed!
Posted on Oct 29, 2011
  • 4 Answers
I've had my Duet for 5+ years with no odor until the past 6 months or so. Even changing to a more fragrant fabric softener didn't make my cleaned clothes and towels smell clean. After reading all the suggestions for resolving this sour odor I thought I would try some of the ideas suggested that I hadn't already tried. Then it dawned on me that about 6 months ago I switched from a powdered detergent (SA8, an Amwy/Quixtar product) and dryer sheets to a well-known well-ranked Liquid Detergent and a fabric softener. I only switched because my son like the way his friend's laundry smelled when he borrowed a shirt. I was using fragrance-free products. Maybe this change was the cause. So I've ordered another box of the powdered detergent and I'm going back to dryer sheets.
In the meantime I'm still doing stinky laundry. Same day I order new detergent, I decide to wash a load with some very stained baseball pants. I sometimes use a small amount (1/4 cup) of Oxy Clean, but I decided to go full-strength which on the box said 1 cup. Hot water wash. Put it in with the clothes. Same liquid detergent, no fabric softener. When I took out the laundry, for the first time in months, it smelled clean. No stale, sour odor. Next load, nice smell again. Decided to do one more load with 1 cup Oxy Clean again. I'm still going to switch back to the SA8 (which is by the way highly ranked by Consumer's reports) and dryer sheets.
By the way, a few weeks ago I had to disconect the water discharge line behind the washer. The sludgy goo that was in the line and machine where the two connected was disgusting, but didn't smell bad. I cleaned it out with my finger. Ugh!
Posted on Sep 17, 2008
Uh.....excuse me....but you ought to not have to buy something to keep clothes from souring....mine have been terrible since the new washer. I never feel clean!!!! My old washer was a clunker and a good one...my clothes were always clean. This is ridiculous.
Posted on May 20, 2008
Make sure that the discharge hose from the machine rises to the height of the machine asap, then falls to the discharge point. This minimises the amount of residual water that can fall back into the machine. Also, when thge discharge hose from the machine, is fitted to a spigot on the sink waste trap assembly, waste water can potentially fall into the machine, if not installed with a high point as described. This type of water can become smelly in a very short time.
Hope this helps,
Regards,
Desperateden ( plumber )
Posted on Apr 08, 2008
I had the same smelly problem. I used 1/2 cup All dishwasher soap on the sanitary cycle. worked great for me. No more smell
Posted on Sep 28, 2007
Whirlpool has recognized there is a problem with the Duet machines and in the great american marketing tradition have come up with, no, not a creative, free fix to solve whatever engineering and design flaw created the problem but, yep, a new product that you need to buy if you want to keep your clothes from smelling like they've been soaking in a mold bath (which, is, er, exactly what they've been doing). Supposedly, you drop one of these tablets (3 for $7) in the machine each month a voila -- no more smell. See www.affresh.com.
Posted on Sep 27, 2007
OK it worked! No more mildew and sour smell. I am calling Whirlpool (1-866-698-2538) to ask them to send me for free the "new and improved design" (as described on www.appliancepartspros.com) of the water drain pump for my machine model GWH9100LW1. This whole situation is caused by the water not fully draining out of the machine and stagnating and mildewing everything in the drain plumbing. This contaminated water can easily get back into the wash tub and onto clothing...something it will absolutely not do if the pump is stronger...which is why they redesigned it.
Posted on May 09, 2007
Hi again, I decided to take the machine apart myself and indeed...the drainage plumbing is full of mildew as are the filters. No wonder the thing stinks. I carefully and delicately cleaned out the pump and am taking all the flex hoses to a carwash to powerwash them out. If you don't want to do all this, I found a website which claims to have a product which will clean out mildew from the inside of the washing machine's plumbing...without taking it apart. The website is www.smellywasher.com and their product is called Purewasher. This stuff is supposedly better than bleach for maintaining the machine. If you need a drawing of how the thing is put together go to www.appliancepartspros.com and they have the exploded diagram and all the parts labeled. Good luck and I hope this helps you.
Posted on May 08, 2007
Hi, I have exactly the same problem. It is particularly bad with the towels. Called Lowe's today and was told the following: 1).Thoroughly clean the grey gasket inside and out and check to see if socks etc. are stuck behind it. 2). Run the machine through a cycle with 3/4 cup of bleach. 3). Always leave the door open and use the He detergent as it suds less than other detergents and these suds can cause the thing to mildew...? 4).If all that fails check the filters at the back of the machine and make sure they are clean and the machine drains properly. I have yet to do all this so I can't say if it will make a difference...I called Lowe's today. If it doesn't, I will call a Whirlpool repairman who has dealt with this before.
Clothes have a sour smell to them after being washed; what is the problem?
my mom always told me that after you use the washing machine, you have to keep the door open. otherwise, mold and mildew will flourish, and it will get on your clothes when you wash them.
Jul 22, 2012 | Whirlpool Washing Machines
I have a Maytag Model MHWE300VW11, Serial CSW5002000 and the clothes never smell fresh. There is always a mild sour smell. I always wipe out the washer and wipe all around the gasket in the tub and I...
you could look for a build up of muck- old soap powder etc around the main door rubber, there are places where the muck will collect. put your fingers right inside the door rubber as there are gaps that are hidden . this muck builds up and causes a horrible smell
Aug 29, 2010 | Maytag Washing Machines
Clothes are sour after wash
The odor is being transferred from your washing machine. The washer must be cleaned first or the clothing will be reinfected upon washing.
The problem area is always just above the normal waterline where suds and soiled water splash up and don't get rinsed out.
To clean your washer add 1 cap of smelly washer cleaner to a full load of laundry in a hot cycle. The added bulk of the laundry will raise the water level to include the "splash area". Intermittent pausing to soak is a good tip for more extreme problems.
Jul 06, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Sticky smelly sour clothes that were just washed in the horrible LG washer. Never recommend this crappy appliance. How do you get this company to be responsible? I got an extended warranty thru GE that...
You have to leave your door and detergent compartment open after every wash. Try using Tide washing cleaner for the machine to get the smell out first, then follow the steps above.
Jan 30, 2010 | LG WM-2277HW Front Load Washer
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Jun 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Sour clothes smell from washer
Until you can find the filter (I'll investiate!) I suggest running it on hot hottest wash you can (empty) with just bleach. That at least should kill the bacteria that are causing the smell
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine smells mouldy- washing stinks!
Find out where your filter is; it is at the end of the thick hose coming down from the bottom of your tub; open up and clean out. Another possibility is there could be something stuck in your drum, feel if you could locate it. Next clean out the hoses in machine. After all this flush out with a hot wash, without clothes. People shd ask the service man where the filter is. If he knows that is.......................It gives you the biggest problem if you dont check.
Mar 19, 2009 | Whirlpool Washing Machines
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
Aug 07, 2008 | LG Washing Machines
Lg tromm front load washer machine
Try using www.affresh.com, in the wash using hot water. If your unit has a tub clean cycle use it. Leave the door open after using the unit to allow it to breath and wipe down the gasket. Use HE detergent and you don't have to use too much. That goes for the fabric softener as well.
Sgt 48
Jun 07, 2008 | Washing Machines
Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Feb 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
12,248 people viewed this question
Sal De
Marvin
Marvin
jimorris77
