Question about LG WM1812C Front Load Washer
LG washer (WM1832CW) error: UE
The LG washer (WM1832CW) always have the same problem of being unbalanced during Spin and Rinse cycle (error: "UE"). This has always been a recurring problem since the first time I used it. In the past, I
usually ignored the problem by rewashing the same
cycle until the unbalance issue goes away.
Lately, this problem has gotten worse. For example,
as I am writing, I am rewashing my same set of clothes
for the tenth time since two days ago (no
exaggeration) because of the unbalance factor.
Believe me, I have tried multiple times by either
removing or adding clothes, taking all the clothes out
and putting them back in, etc but nothing seems to
work.
Please help!
I understand I have owned the product for about a
year, but please understand that this is a not by any
means a working washer machine since day one. I've
also had the washer serviced by your company
(Reference #: C05123003754), but the service
representative did nothing to resolve the issue.
At this point, my patience is running thin and I am
gettting very dissappointed with LG and its products.
Please let me know if there is anything you can help
to solve this problem.
    Genius:
  • 1,036 Answers
This is a problem with modern machines that have a lot of sensors - compared to older models that just used to bang about a lot.
The dampers on this machine may not have been 100% since day 1, so should be replaced. It is their job to reduce the bounce in the drum. As a "belt and braces" attempt, manufacturers often fit foam blocks to the sides of the drum, and there is no reason why you shouldn't fit larger ones to fill up the gap entirely. Foam is cheap, so just use silicone to attatch it either side of the drum - leaving just a centimeters clearance on each side.
This should solve the problem.
Posted on Dec 31, 2008
Why do all loads in our Top Load HE Washing Machine - Model # WT5070CW - stop because of UNBALANCED LOAD ERROR?
1st check ur floor level if the floor level is not flat means sure the error will come.. and dont put a blanket with other clothes
Feb 26, 2015 | LG WT5070CW White Top-Loading Washer
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
My WM1832CW front load machine consistently gives me the UE error code during the spin cycle regardless of the contents or size of the load. Its a direct drive system - so what could be the problem?
bad imbalance sensor. silly little contraption that sticks off the back of the drum. It is a plastic lever with a light sensor attached to the end. there is a hole and a bb that sits in the hole. when the load gets imbalanced, the bb gets knocked out of the hole and the light shines through the hole. the light sensor relays the error to the computer and it displays UE. I took the sensor apart, and put a piece of tape over the hole so the light cant shine through anymore. No more UE code. LG parts are very hard to find. I dont mess with them, but it was my neighbors machine. This will get them by until they can buy a new washer. good luck.
Jul 20, 2011 | LG WM-1832C Front Load Washer
I have a LG WM1814CW front load washer. I get UE when it trys to go on spin cycle. I re-arranged the load and still comes up UE. I also tried a cycle without anything in the washer and still the same...
The UE error code is nothing to worry about. It indicates an "unbalanced error"¬-your washer's way of saying that the drum is not spinning is a smooth rotation. It could be as simple as rearranging the load in the drum (click image for zoom). Here's why:
1) Small loads. Your washer operates better when the weight of the load is evenly distributed across the drum, but that is not always possible with small loads.
2) Mixed fabric loads. For example, if you're washing jeans and t-shirts, the jeans could be on one side and the t-shirts on the other, causing the unbalance. Try rearranging the items and spin again.
3) Large single items. Items like sheets, blankets and comforters tend not to spread out evenly, causing unbalance when the drum spins. Rearrange the item and start the spin cycle over.
4) Spin Sense Option. If your washer has the Spin Sense Option, it may try to adjust the load on its own. If that happens, the washer would slow down and tumble a few times slowly during the spin cycle and then speed up until the problem is resolved.
Hope this helps.
Jun 24, 2011 | LG WM-2077C Front Load Washer
The washer shows a UE error during the final spin. It does not reach the fast spin speeds, but shows the error after 5 minutes.
hello ue is an unbalanced error one of the first things you can do according to lg is click this link to try to aleviate the issue http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800 also check with a level that your unit is leveled if it is not then you would get this error code as well if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Apr 21, 2011 | LG WM-2277HW Front Load Washer
My washer seems not to spin properly during the rinse cycle and will not spin now i get what i assume is an error message ue when its time for the spin cycle to begin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 18, 2011 | LG WM2455 Front Load Washer
Goes Through Wash Cycles Empty Or Full Stops At Spin And Says UE About 4 Minutes Before End
An UE Error Code is indicative of a “Unbalanced Error”.
This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum.
Thank You
Sep 08, 2010 | LG WM1814CW Front Load Washer
Ue error code on my LG WASHER
Hi there
hope this helps you .
UE - Unbalance switch error Unbalanced load is sensed three times during a spin operation. Open lid. Rebalance laundry load and close lid.
· Check wiring harness
· Check unbalance switch
· Check circuit board thank your for writing to fix ya.
Best regards Rich
Dec 08, 2009 | LG WD-16115FD Front Load Washer
Error Message and Tub not spinning
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Jul 21, 2009 | LG WM-2277HW Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
LG WM1812C Front Load Washer Logo
588 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
