Question about Amana ASD2628HE Side by Side Refrigerator
No water flow
I just installed an Amana SDZ27ML side by side refrigerator/freezer.(No information is available for this model). The water line is hooked up but I get no water flow at the dispenser. I don't believe the air is purged from the supply line. Hopefully I have the ice maker shut off. (The feeler wire is in the up position.) What do I do to get rid of the air and establish water flow? Where do I get a manual for this unit.
Make sure the plastic pipe is not bended. I had same problem what i did is replace it with a stronger one.
Posted on May 05, 2007
Amana refrigerator A4TXNWFWWO1 >top freezer, bottom fridge it's only 10 months old refrigerator won't get colder than 55 degrees freezer is working
There is something plugging the drain line in the freezer which carries water from the defrost cycle to your evap drain tray in the bottom of your fridge. The water has built up and froze plugging the flow of air from freezer to fridge.... find the line and unplug it and let fridge sit and thaw overnight and then some more.
Jul 19, 2011 | Amana A4TXNWFWW Top Freezer Refrigerator
THE WATER GETS FROZEN INTO THE PLASTIC TUBE ROLL WHICH SERVES LIKE A DEPOSIT TANK TO COOL THE WATER.
the fresh food side is too cold . if colder than 38 deg it can freeze water tubing . there are kits for amana and maytag and jen air to prevent this ( and what is in kit is rubber shelf blocker strips that install on the back edge to prvent change of air flow . they can be ordered from amana for your model .. and you might ck the tempt in fresh food side and adjust to 38 deg . this can help . also adjust the freezer to a higher # this will slow the cold air comming from the freezer side . hope this helps mm
Dec 11, 2010 | Amana 22.6 cu. ft. Side-By-Side...
What do I need to check to see why my water dispenser is not working on my refrigerator?
Remove the bottom kickplate . Follow the water line , from the bottom of the freezer door , about 6 " to a connector . Push in on the white ring , and pull out on the line , at the same time . Close the freezer door , and push in the dispensor pad for water . If water flows from the tube under the refrig , then the water line inside the door is frozen . You can either turn the freezer temp up slightly , for several days , or use an air tank , to blow out the frozen ice from the line ( I have read ) . There is a heater available to keep this problem from happening , pt. # WR49X10173 .
If water does not flow from the line , you need to replace the dual water inlet valve , behind the refrig , the piece that the wall water line connects to , pt. # WR57X10051 .
Nov 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer building up with frost
Sounds like the defrosting system has a faulty timer/board, faulty heating element or bad electrical connections to these components.
More info, let me know...
Charlie
Aug 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Water dispenser not working
I have a Hitachi R-M800GM.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
Please help.
Thanks,
Rick
May 31, 2009 | Amana ARS2464B Side by Side Refrigerator
Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana Icemaker not working
Sign guy, you have a bad water valve on your fridge. It's allowing a very small amount of water to bypass it and enter into the freezer section Ice Maker fill tube where it freezes. (I always pull those fill tubes out through the back of the fridge and run them under hot water, then blow through them to ensure that it's clear.) You'll need a new valve assy. for it. Open the fridge door and find the data tag, get the model number off of it and call your local appliance parts place. It'll be a dual coil valve assembly.
Jul 21, 2007 | Amana SXD524VW Side by Side Refrigerator
Amana ASD2628HE Side by Side Refrigerator Logo
83 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
