Question about Hotpoint RGB524 Gas Kitchen Range
Hotpoint RGB524 pilot won't light
The pilot for the oven lights fine, but neither pilot for the stove top will light. There is a brief flash on both when flame is applied, as if there is some gas getting to the pilot. I have tried adjusting the valve but no help.
I have used a needle to clear the pilots as well as vacuuming.
Thanks
    Sergeant:
  • 311 Answers
Sounds like you have a standing pilot system.if so and you have turned up the adjustment screw and no better .you will have to replace the pilot tube assemblie
Posted on Dec 31, 2008
I am wondering how I'm supposed to light the pilot on a Hotpoint stove. I think I'm supposed to lift up the cooktop, but I can't get to lift up. It feels like its locked/screwed down somehow but I c
Hot point has 2 pilot lights on top... light them... then go to oven and light that one... it is a safety feature... no pilot on top kills the pilot in the stove.
.. since gas is heavier then air the company made sure if there was a gas leak on top that it would not be caught by oven and blow up.
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
Can't seem to access Hotpoint Stove Pilot Light? Also is there a second pilot light for the oven?
For the last 10 years or more there are no pilot lights on gas ranges. Modern ranges have an electronic igniter on the burners and a different type on the oven.
Oven pilot light won't light. Stove burners work fine.
if you have a pilot flame oven replace your thermocouple
if you have a newer oven you will have an ignitor
please advise me on whitch type of oven you have
Feb 05, 2013 | General Electric ge JGBS04BPW wb1k5 Oven...
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Where is the Hotpoint RGB524 Gas Kitchen Range pilot light located and how do I get it lit? I turn knobs and hear a spark sound but no flame. Thanks in advance..
The spark should light the pilot automatically. If you open the broiler door and look up at the left rear side of the burner, you should see the pilot assembly and the spark igniter. Try lighting the pilot by hand with a match, right where the spark is. If it lights, the oven should come on. If it doesn't light, there may be a blockage in the pilot assembly, like a spider web or something. If the pilot seems too small, it may set for LP and you are on Natural gas. The adjustment for that is behind the oven knob, a screw. Good luck.
Mar 27, 2010 | Hotpoint RGB524 Gas Kitchen Range
Oven Pilot Light
hi not sure but if your oven is activated like the gas hobs? ie electronic spark? not actual flame pilot thentry this ? turn gas dial to start? or the rq'd temp setting? then push/press the dial inwards whilst you press the ignitor button for hob ? rather like the operation start up of mobile valor gas heaters??
Oct 29, 2008 | Hotpoint RGB524 Gas Kitchen Range
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Hotpoint RGB524 Gas Kitchen Range Logo
652 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
