Question about Samsung RS2630SH Side by Side Refrigerator
Refrigerator making noises
Unit is only one year old. The model number is RS2530BSH not RS2630BSH but this site would not let me enter the model I have so I picked the model closest that came up.
Its a twin flow unit so I think its one of the fan motors and specifically, the one in the freezer section. But I cant be sure until I can get inside the area.
How do I get inside the compartment I need to get into? I tried to take the middle section out. I took the screws out and tried to gently pull it out but it won't budge. Maybe its frozen or maybe I need to take either or both the above/below panels out as well-- i don't know.
Can someone tell me the part # I need to order? I'm pretty sure its the fan motor but I wanted to get it in my hands to be sure so I can make sure the amps/rpms match whats in the unit.
Here are pics of what I see so if anyone can tutor me on how to take the panels out to get to the motor/fan area, I'd be most appreciated.
http://img155.imageshack.us/my.php?image=sam1kr2.jpg (this contains the motor but I cant open it. do i need to gently but firm pull on it? are there clips/brackets on top that I have to be careful with?) http://img525.imageshack.us/my.php?image=sam2qj0.jpg (panel below, do I take this out to get to the middle section first?) http://img528.imageshack.us/my.php?image=sam3vp2.jpg (panel above, next to the icemaker but doesnt look like the icemaker has to be removed but perhaps the tray to get to the panel to take off?) If someone can help me describe how to take out, thank you. Got a part # as well so I can order and get to it and live with the noise until then. Thank you.
  • 3 more comments
  • WiscUSA Jan 01, 2009
    Big help: become a member here. SIGN UP!
    Why? cause I wasn't able to see all the other problems w/advise or remarks until after I signed up to post my problem.
    Please read the entire fixup solution but only use the last suggestion for repair.
    What I saw was that one person just removed the screws from the center part and saw icebuild up. Used something like a bottle opener to get the center part out.
    I thought if ice buildup was the issue, I wanted to make sure. So with the info on how to remove the center part, I decided to give it a go.
    First I really didnt want to damage the soft styrofoam behind the thin metal panel, so I got out the hair dryer out and helped defrost any ice buildup between the panels and the shell of the refrig. After a few minutes, i then used a paint can opener (like a can opener as it has a narrow hook). Once you pop those small white plastic pieces that hides the top screws, there are small opening created. I fit the can opener inside the lower holes and gently tugged and a small bit of umpph, the center panel popped open. Then you gently lift a bit and the lower lip is moved out of the track to hold the lower end in.
    Then I saw what was making the noise. ICE.
    The ice built up in a huge chunk so that it was moving or pushed the fan blade out of alignment and scraping the plastic housing it sits in. It was intermittent probably as sometimes the ice melted a bit and it released the blade to let it go around again and started up again when the ice rebuilt up.
    I used the hair dryer on the ice build up and gently used the plastic end of a screwdriver to break it up and it fell off. (I'd say, dont ever poke a sharp instrument in a refrigerator) It took a few seconds to get the ice cleaned off.
    Then reinstalled the panel and cleaned the freezer and put the food back in from the basement freezer.
    Now it sounds like...ummm...what sound?
    So after my explanation, this is what I recommend to everyone. DO NOT DO ANYTHING! Just store your food in another freezer/cooler and unplug the refrig, leave open the doors for faster de-icing and a few hours later---its fixed.
  • Anonymous Jan 19, 2009
    same problem, the fan was replaced, but the water was frozen again and temperature does not reach the appropiate 5 degree value. I will like to know whats wrong.
    L Soler M
    Problem Solver:
  • 17 Answers
It is normal that a new refrigerator make noice. Open the door(s) and check on the switches, and look for the source of the noice.
Posted on Aug 11, 2009
How old is this refrigerator?
Mike,
If you put in the make and model for your unit, it did not come through to us. If you go to this website link, and scroll to the bottom of the page and enter the requested info, they will tell you the age as close as they can. Several manufacturers recycle their model and serial numbers every 11 to 12 years, so you may have several year dates to choose from. Hope this helps! Appliance411 Service How old is my appliance Age finder date of...
Jun 07, 2015 | Refrigerators
My samsung rs2530bsh is heating up in the center between the two doors its so hot you can even touch it what can this be from
this is because the condenser fan is not doing its job open the lower panel in the back of the unit and make sure that the (condenser)fan is working if it does then the coild and very dusty , get a long brush and clean the condenser coils you will see a diff. right away
Sep 05, 2011 | Samsung RS2530BSH (25 cu ft) Side by Side...
The fan motor started making a sqealing sound about two weeks ago. Then noticed a burning smell this morning. Checked it again this afternoon and the plastic divider between the fridge and freezer is so...
you indeed do have a bad condenso rfan motor.. its the fan by the compressor behind the unit,,i couldnt find your model number on my part look up, but you can call samsung direct( cust service line) and with the entire model and serial number they will be able to determine the correct part number, you want entire condensor fan assy with housing and fan blade... it will come complte, you will simply unplug and snap in the new unit housing and all.. inn meantime i would pull unit away form wall and with a desk top fan orwindow fan blow it on te compressor to keep it cool you dont want to overheat the compressor. the youll have major problems
Oct 09, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Warm refrigerator and freezer
May be a bad defrost timer and the evaporater is froze up with ice. Clean dust buildup from the condenser under or behind the unit. Always give the model number
May 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore elite refrigerator is making buzzing noise and the freezer is not making ice.
It appears your compressor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Sears microwave oven model number 564 8568511 When you plug it in the outlet it hums and the megitron tube comes on and it heats without seting time or power. It just hums and heats without the fan coming...
This is probably a shorted triac or relay.
You can find exploded views and order parts by entering your model number at the Sears parts site.
There may also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 25, 2008 | Microwave Ovens
I own an LG up right refrigerator with the freezer on the bottom. The unit is about three years old and we have been very happy with the frig. Lately the unit has been making a loud fan winding noise....
  • i would just replace the fan motor $40
  • they have bushings in them that sometimes make noise when the motor shaft moves to a certain position. when you open the door it disrupts the airflow of the refrigerator and the motor shaft will go to a different position causing the noise to stop.
Jul 10, 2008 | LG Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
75 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
