Question about Hobart Food Mixers
Question about model numbers
What is the difference between the Hobart H600 and the Hobart H600-DT??
Is there a list somewhere of all the different meanings behind the model number suffix's found on the varying similar models?
  • 125 Answers
Hi, the "T" means it has a timer, not sure the "D", digital maybe? There are a few Hobart guys on here, maaybe they will post, or you can call your local restaurant equipment dealer, thay should be able to help you.
Posted on Jan 04, 2009
What is the difference between a H800 and L800 mixer
I have used the H600. Nice piece of kitchen kit for hard use.
Model H600 is a heavy-duty 60-quart mixer which features a two-horsepower motor, a timer and a #12
Attachment Hub as standard equipment. With the use of bowl adapters and special agitators, 30- or 40-
quart bowls may be used on the H600.
Model L800 is a medium-duty 80-quart mixer designed primarily for use in general kitchen applications.
This mixer features a timer and #12 Attachment Hub as standard equipment and is powered by a
two-horsepower motor. With the use of bowl adapters and special agitators, 30-, 40- or 60- quart bowls
may be used on the L800.
A Bowl Guard is standard equipment on all H600 and L800 models.
A programmable timer controller is optional on H600 and L800 models.
These mixers can be ordered with a stainless steel finish.
A variety of attachments and accessories are available for all mixers. These are described in a separate Use and Applications Handbook, which is furnished with each mixer.
Here is your manual.
May 07, 2016 | Food Mixers
I needed to know the PH for a h600 11344142 Hobart mixer... And is it a single Or 3 face??
Hello Jbabajanov,
I understand that you want to know about the HP (Horse Power) of a H600, 60 quart mixer and weither it is a single or three phase.
All H600 Hobart mixers are equiped with a 2 horse power motor.
As to wether it is single or three phase you will need to look at the service tag of the machine. If is listed on it weather it is single or three phase.
Thank you for choosing
May 13, 2011 | Hobart H600 Stand Mixer
What oil can you use for the hobart h600
on the hobart h600 we use 120 oz of 140 weight gear oil.
Mar 04, 2011 | Hobart H600 Stand Mixer
What type of gear lube should I use for my Hobart H600 mixer?
Hi, btperduell
below is a copy of an e-mail from I searched the web forhours for the correct oil and could not find any info so I e-mailed Hobart. The Planetary is a different part from the transmission andthe sight glass on a M802 is for the oil in the transmission. The answer that Hobart gave is not an NSF oil. Ineeded the oil for the planetary section on a model M802. Even the directionssay that it is normal for a drop of oil to occasionally drip from the seal.That is where the dough hook attaches. I am in the process of researching the oil and Exxon / Mobildoes make a NSF version. I just need to find somewhere I can buy less then a 55-gallondrum. The above mixer only uses 6 ounces. Take care and stay safe Thank you Mike Hobart E-mail follows ============================================================== Mike, Hobartuses "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer - Food Machines Product Service - Tech Support
Jan 15, 2011 | Hobart HL600 Legacy Stand Mixer
Trying to find what the shaft assembly looks like on a Hobart H600 Mixer
b1sam - You might try using the very easy "Hobart" smartparts webapp on the Hobart website. Cut and paste this into your browser Address line: From there you can select from 19 assemblies to review. Each assembly includes a parts list and an exploded view of the assembly. Based on your comment 'shaft assembly', I believe you want to look at either #12, Transmission Unit or #13, Planetary Unit.
Good Luck... I hope this is helpful.
Howard, Burke, VA
Nov 19, 2009 | Hobart H600 Stand Mixer
Got a hobart mixer model h600-t cutting off and kicking breaker,it runs sometimes for about 5 min. when the ladys are mixing bread,checked amps,not under a load
If you can access the brushes you may want to inspect them. If anything but the carbon brush is touchiing thhe armature. It with trip a breaker.. Unplug it before accessing the brushes < -- my disclaimer :)
Oct 27, 2009 | Hobart H600 Stand Mixer
How do you change the oil in a hobart h 600-dt dough mixer & what type of oil do you use ?
there is an oil case drain pulg under the top by the clutch, you can drain the motor housing through there, \
i have used 5w30 in a pinch
but it would be better if you ordered hobart oil from the website
its cheap but very very good
Oct 15, 2009 | Hobart H600 Stand Mixer
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
I might be interested if its a bargain
Dec 11, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
116 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
