Question about Dell OptiPlex GX260 PC Desktop
DELLS DISK MONITORING SYSTEM HAS DETECTED THAT DRIVE 0 ON THE PRIMARY EIDE CONTROLLER IS OPERATING OUTSIDE OF NORMAL SPECIFICATION
  • 728 Answers
Hi akaprettyboy,
It is advisable to immediately back up your data and replace your hard-disk drive as soon as possible. If you are able to boot consider yourself lucky for now, but that error finding a POST queried EIDE drive detected possible error conditions means the drive is either Unreliable or a defective drive. You can try to reformat the drive (once you backup your data) to try and save it, but most likely it's trashed.
Best of luck
Mark
Posted on Dec 31, 2008
Just inherited a d410. runs XP pro. whats largest hdd I can upgrade to?
Disk-drives either have an EIDE interface or a SATA interface.
The largest EIDE disk-drive is 500 Gbytes.
SATA disk-drives can be much larger.
Check the manufacturer's web-site: http://support.dell.com
and select your model-number, and read the "specifications",
to determine whether you have an EIDE or a SATA disk-drive.
Oct 16, 2010 | Dell Latitude D410 Notebook
Dell's disk monitoring system has detected that drive 0 on the primary EIDE controller is operating outside of normal specifications
Take this as a S.M.A.R.T. drive warning and start backing up your valuable information. Be prepared for a drive failure.
Mar 15, 2010 | Dell Dimension 2400 PC Desktop
My laptop had a ''smart failure predicted on hard disk 0: toshiba mk4025gas-(pm) Warning: immediately back up your data and replace youre hard disk drive. A failure may be imminent'' what does this...
This means that your laptop's motherboard has detected that the hard drive (where all of your data and operating system live) is operating outside of normal parameters. Hard drives are supposed to read/write/respond within specific parameters. If the drive stops operating within these parameters, it usually means that the drive is failing, and therefore your information should be backed up, and your drive should be replaced. Once you back up your data, you can contact HP support to get the hard drive replaced.
Mar 03, 2010 | HP Computers & Internet
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
I need a driver for my sound card
how i solve problem plz contact yhis email shaurakhkhan@yahoo.com
May 28, 2009 | IBM Computers & Internet
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
DELL COMPUTER
Step 1: Switch to SATA.
Dec 31, 2008 | Dell OptiPlex GX260 PC Desktop
Dell's DISK MONITORING SYSTEM HAS DETECTED THAT DRIVE 0 ON THE PRIMARY EIDE CONTROLLER IS OPERATING OUTSIDE OF NORMAL SPECIFICATION WHAT DO THAT MEAN
Modern IDE hard drives have built in diagnostics called S.M.A.R.T on them, which can detect and predict when a drive is about to fail.This is the system that is throwing up the error. I suggest you back up any important data immediately and get ready to buy a new drive.
I still cant figure it out....no sound...
Uninstall Previous Sound Drivers & Install new one. I am online now & can help you out with remote assistance.
Aug 06, 2008 | Computers & Internet
Dell OptiPlex GX260 PC Desktop Logo
111 people viewed this question
Alun Cox
